Gas tank hard to fill
Old Jul 19, 2006 | 03:59 PM
pilot1777R's Avatar
pilot1777R
Default Gas tank hard to fill
I have a 2005 ZR touring redline. I bought the car in April and have had trouble filling the gas tank since day 1. I would put the nozzle in the tank and it would pump about one time and the gas would gush back out. After about 3-4 gallons, the tank would fill normally. I read some other posts about turning the nozzle upside to fix the problem, but nothing worked for me. I found a service bulletin about a defective shutter valve in the tank and I got it fixed today. I filled up with gas and had no problems. I just wanted to share this with anyone else who might be having the same problem.
Pilot
Old Jul 19, 2006 | 07:07 PM
Morningglorie's Avatar
Morningglorie
What did they have to do to fix the shutter valve? From reading the bulletin, it looks like they have to take a lot of stuff apart and that worries me.
I had a problem a couple weeks ago - started to fill the tank and the nozzle jumped back out, sprayed gasoline all over me. I think the shutter valve must not have been completely open and I didn't notice it, was just going on habit instead of paying attention.
Anyway, gasoline sprayed all over my legs and skirt and splashed on my face before I managed to shut it off. Very scary, as you can imagine. I had some red marks on my face for a few days before it healed up.
We were out of town so I didn't want to take it to some random garage. Haven't had any problems since then but you better believe I have been VERY careful to make sure the shutter valve is open and the nozzle is fully inserted before filling up.
I looked for my VIN number on the recall list and it wasn't on it. If your number is not on the list but you still have the problem, will they still fix it under warranty?
Old Jul 20, 2006 | 02:59 AM
pilot1777R's Avatar
pilot1777R
There wasn't a recall on the valve. The tech's told me some fuel hoses had been recalled, but not on the 2005's. The work order said the shutter valve "had an internal failure" and it took about 3 hours to fix.
I had problems filling the tank regardless of how far I inserted the nozzle into the tank. I tried everyway possible to put gas in the car and it always splashed back out. I even tried 4 different gas stations and it happened everytime I filled up.
Hope this helps!
Old Jul 20, 2006 | 03:43 AM
techcontrol's Avatar
techcontrol
The first week I had my 05', I had this issue. After I filled up the second time, never had a problem again.
Old Jul 20, 2006 | 09:19 AM
BLKroadster's Avatar
BLKroadster
Mines hapen off and on. But I notice if u fill it slowly instead of pressing it all the way u can fill it up more.
Old Jul 20, 2006 | 11:16 AM
Built2shredZ's Avatar
Built2shredZ
Never had that problem... Wonder if your gas pumps are different then california pumps <shrug>
Old Jul 21, 2006 | 12:02 AM
z_roadster's Avatar
z_roadster
+1
Old Jul 23, 2006 | 12:29 PM
JMT's Avatar
JMT
I have a pre-owned 2004 ZR and have filled it 5 times since I bought it on July 1st. I had this problem for the first time this last fill-up. I had about 87 miles dte. I got about 4 gallons in it before the pump quit (this was at a Chevron station). I drove around and went to a Unocal station and had no problems filling up. I wonder if the intermittent issue is the car or dependent on the pump.
Old Jul 23, 2006 | 07:45 PM
Built2shredZ
Do you guys hold on to the nozzle while you pump? This could be the cause
I always just put it in, pull the trigger, then flip up the lock lever and let go while it fills up.. Have never had a problem yet..
Old Jul 23, 2006 | 09:02 PM
Morningglorie
I usually hold on to the nozzle, like I've been doing for the past 30 years or so. That one time a few weeks back when the gas spewed all over was the only time I've ever had a problem.
Have to think it was the car. Very slight possibility it was a problem with the pump.
No problems since then, but the incident has made me very, very cautious when filling up.
Old Jul 23, 2006 | 10:17 PM
JMT's Avatar
JMT
Nope, I always use the trigger lock.
Old Jul 24, 2006 | 09:10 AM
m9999's Avatar
m9999
how much did it cost to have the shutter valve replaced?
Old Jul 24, 2006 | 09:29 AM
Blu Hvn's Avatar
Blu Hvn
This is not an uncommon problem. It happened repeatedly on my '05 Roadster. When I first took it to the dealer they couldn't diagnose a problem. I adjusted how I inserted the nozzle into the tank and had few problems after that. Later a TSB was issued and the dealer fixed under warranty. I don't recall now the name of the part.
Old Jul 24, 2006 | 04:48 PM
z-tired's Avatar
z-tired
This is a common problem. I have taken my '04 roadster in to the dealer and they have ordered the part. You can read the TSB here:
http://www.nissanhelp.com/Ownership/.../NTB05-048.htm
All TSB's (Technical Service Bulletin) are available on this site. My car has had most of them. I don't care. I love my roadster!
Old Jul 26, 2006 | 04:48 AM
pilot1777R's Avatar
pilot1777R
My shutter valve repair was covered under warranty. I read the other posts about how to hold the nozzle and whether or not to use the trigger lock. I tried everything and nothing worked. Now I can fill the tank easily.
Old Jul 27, 2006 | 03:40 PM
DeZigner's Avatar
DeZigner
Had the same problem with my 2004 Roadster. The dealer took care of it under warranty and evrything has been fine since. The dealer mentioned that Nissan said it should take about 30 minutes to repair. The reality was several hours and a few sliced up mechanic hands.
Old Jul 27, 2006 | 07:55 PM
Morningglorie
Yeah, the TSB specifically says to put rubber guards and such on the sharp edges.
Whatcha bet the service techs don't read the whole thing through until there's blood on their hands.
Old Jul 28, 2006 | 05:00 AM
zodiac's Avatar
zodiac
The 2003 was recalled earlier this year (June if I remember right) for the fuel filler hose. Evidently it has the potential to crack. I had the recall done last month on my 03 Z. I have also had an issue (Once) where the car would take gas to about 3/4 of a tank, and then"refuse" more gas. My wife said that her 2004 Altima (3.5se) has done the same thing to her twice. If you have a 2003 and haven't had the fuel filler hose changed yet, check your VIN against nissan's tech site.
Old Jul 28, 2006 | 08:41 AM
InSaNeZ's Avatar
InSaNeZ
Wow, that's the first time I've heard anything about that, weird.
Old Jul 28, 2006 | 09:28 AM
mg350ZR's Avatar
mg350ZR
Originally Posted by zodiac
... If you have a 2003 and haven't had the fuel filler hose changed yet, check your VIN against nissan's tech site.
It also applies to early '04s.
liqalu04
Jan 2, 2022 12:58 PM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
