Can't hear turn signal!
Old Oct 22, 2006 | 01:46 PM
arejohn's Avatar
arejohn
Interesting. Seldom had this problem until my last to cars (06 volvo, 05 350z) and assumed it was age related - mine. Signals on both cars seem to require complete return to 0 degrees before turing off signal. Did older cars turn off during return to center perhaps?
Old Oct 22, 2006 | 04:20 PM
Monsta's Avatar
Monsta
I have an 03 and I can turn it about 45 degs into the turn and back to center, even before it's back to 0 degs and it will cancel out. But like I said, I flash my turn signal and then cut it off. I don't wait for it. And I ALWAYS glance at my gauges esp with my music up. I esp check my oil and volt. Nevermind the speedometer. LOL
Old Oct 22, 2006 | 06:13 PM
maxpowers's Avatar
maxpowers
This problem bothered me at first, but after a while you become more aware of the turn signal. When I take a turn that's less than 25-30 degreess and I use the turn signal, it is natural to check that its off now.
Old Nov 2, 2006 | 05:31 PM
Penderwheels's Avatar
Penderwheels
Default Buzzers
I read the wiring diagrams in the service manual but had a hellova time finding the wires under the dash so................
I got 2 Radio Shack buzzers (12 volt) - each a different frequency. I tapped into the wire behind the headlight clusters (both sides) that goes to the turn signal and ran the wires back under the dash.
I double face taped the buzzers to the topside of the plastic panel under the steering column, added a ground and viola, it worked.
If I wanted to make ot more "sophisticated, I'd add a rheostat to the ground to adjust the volume for top up or top down.
Took about 2 hours, Biggest pain was laying on my back (I'm 68 YO) under the dash to get the wires to the steering column.
Old Nov 2, 2006 | 05:35 PM
Eazzy's Avatar
Eazzy
Very Cool ---Excellent idea, Im going to do that this weekend !!!
Old Nov 2, 2006 | 11:12 PM
sdbarker's Avatar
sdbarker
See, that's sweet. And helpful. Pics? Diagrams? Etc? What buzzers did you use? Do you have audio of the two?
Old Nov 16, 2006 | 02:19 PM
Starchecker's Avatar
Starchecker
This is the one thing I hate about my car too. It's not really the sound that is the main culprit, it's that you have to turn the wheel 90 degrees before it will "realize" a turn took place and click off the signal.
I've never had a car require the wheel to turn that much before it would kick off the signal. I have an entrance on the interstate that turns about 80 degrees, and it's not enough to kill the switch, so I am always on the stupid highway with the top down looking like an idiot!
Old Nov 16, 2006 | 05:50 PM
bamyi's Avatar
bamyi
Wow, you people complain about the tiniest things in life. Remember, the grass is still greener in a Z. Just drive and enjoy.
Old Nov 16, 2006 | 06:50 PM
FairladyZX's Avatar
FairladyZX
the only time i use signals is when i want my zR to be noticeable to other drivers or when po po is around
Old Nov 19, 2006 | 11:42 AM
KombatKing's Avatar
KombatKing
If you wear polarized sunglasses with the top down you can still see the turn signal just fine - even in the bright sun.
~KK
Old Nov 25, 2006 | 08:41 PM
Starchecker
That's why I said the ONE thing. It's just such an easy fix for nissan, and I've never driven a car that had that issue with where they set the click off for the signal. I imagine the coupes don't have that issue, since it only happens to me with the top down. No one likes to look like an idiot in a cool car.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
May 30, 2017 03:28 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
