ZR vs. Z rear coil springs
Old Aug 30, 2007 | 01:42 PM
gunslinger's Avatar
gunslinger
Default ZR vs. Z rear coil springs
The rear springs for the roadsters have different part numbers than the rear springs for the Z coupe. I've yet to see an explanation why. Anybody know? Are they really different?
Old Aug 30, 2007 | 02:03 PM
Built2shredZ's Avatar
Built2shredZ
The rear springs on the ZR might be a tad stiffer because of the added weight (reinforcement and roof mechanism)... Otherwise I'm not sure...
I used the Nismo Suspension (coupe) on my Roadster and haven't had any problems.
Old Aug 30, 2007 | 08:10 PM
gunslinger's Avatar
gunslinger
Everything I've found has pointed to the springs being the same stiffness (Rear = 342 from 03-04 and 427 from 04.5 on).
My 04 ZR has stock springs and I think it's lower than stock coupe's. Which makes me think that maybe the spring length is different?
Old Aug 30, 2007 | 10:08 PM
Built2shredZ
It could be there just the same but since there for different model cars they give them different numbers, even tho there the same...
Otherwise the Coupe Nismo Suspension Kit I got wouldn't of lowered my car..
Old Aug 31, 2007 | 09:30 AM
Zazoozle's Avatar
Zazoozle
I was wondering about the roadster suspension too... I just bought hotchkis springs and sways to put on this weekend...am I right to assume I won't have any problems?
Old Aug 31, 2007 | 09:31 AM
iStan's Avatar
iStan
ZR
You will have no problems with your sways. I imagine springs will be fine too
Old Aug 31, 2007 | 09:33 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
From my understanding the springs are the same but the roadster sit a tad lower because it weighs about 200 pounds more.
Old Aug 31, 2007 | 11:13 AM
gunslinger's Avatar
gunslinger
You'll have no problems with either. Even if there was a slight difference between zr and z springs, I doubt you'd notice anyway.
I also want to point out that it's not just the part number that's different. The springs are also marked differently. Which makes no sense at all if they're the same.
Old Aug 31, 2007 | 01:28 PM
Zazoozle's Avatar
Zazoozle
Sweet, thanks everyone - Arg! I'm on the edge of my seat today cuz I can't wait to leave work to go work on my car!
once I get my Zr a little more modded, I'll post some nice pix!
Old Sep 15, 2007 | 08:40 AM
lewmar88's Avatar
lewmar88
Getting the same setup. Would love to see some pic's and here about the rear springs and any bottoming out issues. Thanks
Old Sep 15, 2007 | 12:58 PM
Delako's Avatar
Delako
I got the S-tune on my roadster, no problems.
