roadster trunk won't open
Old Oct 31, 2007 | 05:31 PM
Zivman's Avatar
Zivman
Default roadster trunk won't open
We are working on a roadster and we can't get the trunk to open. We don't have the key fob, only a valet key. the rear latch release is not working
any insight on how to open the trunk?
Old Oct 31, 2007 | 06:14 PM
d_le's Avatar
d_le
Open the storage bin behind passenger seat. Pull the latch in the bin. It'll open the trunk.
This is in the owner's manual.
Old Nov 1, 2007 | 06:23 AM
Zivman's Avatar
Zivman
thanks! (oh, and no service manual with the car)
Old Nov 1, 2007 | 08:24 AM
RonF's Avatar
RonF
Download
http://www.nissanusa.com/apps/techpubs
Old Nov 1, 2007 | 09:10 AM
Zivman's Avatar
Zivman
Originally Posted by RonF
all right, more help needed. Trunk won't release nor will the fuel door release. Fuses have been checked and replaced. when the button is hit, nothing happens, so it is not just the door sticking or the trunk sticking.
The car had a front clip put on due to a collision. Any more help is appreciated
Old Nov 1, 2007 | 01:36 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
A little more detailed explanation of how to open the trunk from the inside of the cabin.
Attached Thumbnails roadster trunk won't open-trunk_manual.jpg   roadster trunk won't open-trunk_manual2.jpg
Old Nov 1, 2007 | 04:53 PM
RonF's Avatar
RonF
The hidden handle in the glove box activates the trunk release by a cable. No electronics at all
Old Apr 11, 2023 | 10:12 AM
shamsudi01's Avatar
shamsudi01
Hi, after so many years, I am facing exactly the same problem at the moment. Could you tell how did you get the problem solved brother?
Old Apr 11, 2023 | 11:46 AM
Heel Til I Die's Avatar
Heel Til I Die
It was answered in the subsequent posts. There's a plastic cover in the compartment behind the seat. Pull that off and there's a manual release handle that you pull.
Old Apr 11, 2023 | 07:06 PM
shamsudi01's Avatar
shamsudi01
Thanks, man. Could you give any advice on how to fix the electrics part? Not to go to the back of the seat and pull the thing every time, you know. I would appreciate the help as nobody in my country knows that, apparently.
Old Apr 12, 2023 | 05:00 AM
Heel Til I Die
It could be any number of things. Start with some basic electrical troubleshooting to make sure power and grounds are supplied at the appropriate connections.
I have attached the relevant portion of the BL section of the FSM for you. Good luck!
File Type: pdf
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
