Air Bag Light Turned On
Old Mar 4, 2010 | 08:31 AM
MrWatchDawg's Avatar
MrWatchDawg
Default Air Bag Light Turned On
so I get in the car this morning and the car's airbag light is randomly flashing.
its an 05 350z roadster.
is there anyway I can reset it? The car's airbag's have never deployed *Crosses Fingers*
Old Mar 4, 2010 | 09:08 AM
Smasher's Avatar
Smasher
There is a thread on here somewhere about this. There is a sequence you can use of turning the ignition on for a number of seconds and then turning it off again.
This worked for me for a while but now the light is on all the time.
Old Mar 4, 2010 | 02:23 PM
NismoZR's Avatar
NismoZR
Here is the link to reset your bag https://my350z.com/forum/3603538-post3.html
good luck.
Old Mar 4, 2010 | 02:52 PM
MrWatchDawg
but the thing is i never installed any racing seats or anything
Old Mar 4, 2010 | 03:29 PM
NismoZR's Avatar
NismoZR
Check to see if the yellow harness under both your seat to see if they are disconnected or loose. Damage of any kind that is the air bag harness. It wont hurt to reset to see if the light goes away. Did you spill any water to short circuit.
Old Mar 4, 2010 | 04:00 PM
Blooster's Avatar
Blooster
Dealer replaced my '05 ZR driver's seat side airbag 4 times over 4 years, all under warranty, fortunately.
Only symptom was that light on.
No abuse, no water, no interior mods.
Old Mar 4, 2010 | 04:07 PM
Waiz's Avatar
Waiz
Interesting, I though it had something to do with my aftermarket bumper.
I will take a look at my seat, I may have knocked it around since I keep my windsheild visor underneath my seat.
Old Mar 5, 2010 | 02:20 PM
Master Shake's Avatar
Master Shake
I had the same problem a while ago.
Used the key reset procedure a few times. Each time, the light would stay off for 2-3 months, but then come back on again.
Took it into the dealer and he said the connection in the steering column was loose. He said this happens a lot due to vibration, and he tied the connection together by wrapping a piece of wire around it to hold it together.
Cost about $65 for under 1 hours work (out of warranty) -- mostly the diagnostic part and taking the steering column apart.
Old Mar 5, 2010 | 06:53 PM
MrWatchDawg
hmm wonder if that can be done by myself.
Let me try to see
Old Mar 6, 2010 | 08:07 PM
sssmasss's Avatar
sssmasss
try the resetting procedure first. if it doesnt work then get ur car scan. find someone on craigslist in ur area that have a scan machine. i got the same problem and the guy in my area scanned my for 20$. it turned out the rat chew my seatbeld pretensioner. but get ur car scan if the reset does not work.
Old Mar 6, 2010 | 08:10 PM
johnwigs's Avatar
johnwigs
seat belts are lifetime warranty... what is so wrong with going to get if fixed instead of "reseting" the light... it will come back on
Old Mar 8, 2010 | 02:43 PM
MrWatchDawg
I could take it to my friends shop and get him to reset with the little code reader he has?
Old Mar 11, 2010 | 07:11 PM
dfresh713's Avatar
dfresh713
Master
I had the same problem with an '05 roadster, wound up hitting an animal and bringing the car in for body work. They fixed mine for free.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
