top replacement question
Old Dec 29, 2010 | 11:50 PM
MrWatchDawg's Avatar
MrWatchDawg
Default top replacement question
so guys its time, the top needs to replaced. Small annoying holes popped up and makes to much road noise
anyone have any good luck with EZon tops?
im planning on getting this one http://cgi.ebay.com/ebaymotors/ws/eB...ht_3328wt_1084
also do we have a twill weave vinyl for stock? i wanna have stock oem look, dont wanna get something different
Old Dec 30, 2010 | 08:54 PM
MrWatchDawg
no one?
Old Dec 30, 2010 | 10:13 PM
Jennifer 2's Avatar
Jennifer 2
Yes, the stock top is a two-ply, PVC (vinyl) on the outside and a polyester twill fabric on the inside. Nissan uses one of the ubiquitous Haartz top fabrics in their tops, as do most other car manufactures and aftermarket suppliers.
I don’t know anything about Ezon tops. Generally it’s not to hard for these aftermarket makers to match the look and quality of the factory top. One thing to check on though is how the glass rear window is attached, welting etc.
Old Dec 31, 2010 | 07:45 AM
tblunt1's Avatar
tblunt1
https://my350z.com/forum/350z-roadst...eriorated.html
I bought from topsonline.com which lists the vinyl top on Ebay for 479 I think it was. I put pics of the trim around the rear window from old/new so you can compare. Being as how it's now to cold to put the top down I've no idea how much it might have stretched but the few times I put it down after install I had to bump it back up then down to get the hatch/boot to close and lock down but it was probably just 3 or 4 times before it got too cold so it probably just hadn't stretched enough yet.
Old Jan 1, 2011 | 08:33 PM
MrWatchDawg
but the one you have is an EZon top though right because topsonline only has robbins listed on the site
Old Jan 2, 2011 | 04:12 AM
tblunt1's Avatar
tblunt1
Yes, Ezon, here's a link to a current auction they have. Should be exactly the same as the top you listed a link to just 14 bucks more. If you look down through the listing, about 3/4 maybe it specifically states made by ezon.
http://cgi.ebay.com/ebaymotors/Nissa...Q5fAccessories
norrix420
350Z Roadster
May 23, 2022 05:11 PM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
torchkc
Sep 11, 2015 08:26 PM
