Convertible Top Alignment Issue – Left Side Pulling Too Far on Windshield (350Z
Old Jul 11, 2025 | 09:32 AM
Hocis's Avatar
Hocis
Default Convertible Top Alignment Issue – Left Side Pulling Too Far on Windshield (350Z
Hi everyone,
I’m having an issue with my new Nissan 350Z Roadster soft top. I am new in this world but love the car ! When closing the roof, the left side goes noticeably further down onto the windshield frame than the right side, which stops earlier. The result is an uneven fit when the top is fully closed, and from above, you can see that the fabric is not sitting symmetrically – it’s much flatter on the left, while the right side has the normal curve.
Also, I’ve noticed that where the soft top meets the windshield frame (especially at the corners), it looks almost straight on the left side, instead of having that slight downward curve that matches the frame. The right side still has the proper shape and curvature, which makes the issue even more obvious. A professional told me that the whole top would need to be replaced, which would cost several thousand euros.
There’s no apparent damage or noise during the opening/closing cycle, but the alignment is clearly off.
I’d really appreciate advice from anyone who’s had a similar issue.
I had it like this, it will sleep outside during this year...
Thanks in advance – I can share photos if needed.
Old Jul 11, 2025 | 10:48 AM
Heel Til I Die's Avatar
Heel Til I Die
Is that a new or aftermarket replacement top? I have not had a similar issue, but it appears that when it was replaced, during the step where the new canvas is stretched over the flat metal piece (over 3m double-sided tape), the installer did not do it evenly before screwing down the curved retaining piece. You might be able to re-align it. Or, if the top has some wear on it and you're due for a new top, it might be better just to get a new one.
There is a top replacement guide here: https://my350z.com/forum/350z-roadst...l#post11009381
I have attached the removal and install portions of it that deal with that top header piece.
Good luck!
File Type: pdf
File Type: pdf
Old Jul 11, 2025 | 11:01 AM
Hocis's Avatar
Hocis
Thank you for your message.
I think it's an aftermarket, that's how I got it.
Do you think I should buy a new top or can I make up for it? I think it's been like this for years.
I'm afraid it's not the fabric that's the problem but the mechanism or whatever that's misaligned.
Do you know how long it took you to change it? A site for a quality soft top ?
Old Jul 11, 2025 | 12:29 PM
Heel Til I Die
Yeah, it doesn't look like the factory vinyl material, but I'm not sure if everything is the same for you Z guys across the pond. If it's been like that for a while, then it probably can't be removed and realigned - at least not easily.
I suppose it's possible that one of the arms could be bent or something else is not right. I'm definitely not an expert on the matter. A dedicated shop that handles roadster/soft top replacements would be the way to go.
When I did mine, I got it done in an afternoon by myself. It would go smoother with another set of hands. I went with the Robbins/Haartz Stayfast cloth top. Whew - I just checked prices and they have definitely gone up quite a bit. I imagine shipping over there would be even worse. Maybe there's an alternative European manufacturer over there?
I would stick with cloth or canvas over the cheap OEM vinyl material.
Old Jul 11, 2025 | 12:58 PM
Hocis's Avatar
Hocis
Ok thank you ! I’ve seen this one
1500€ for alpaga, expensive now but another will be poor quality. For 600€ on amazon you have one or 200€ on AliExpress (same manufacturer I think, just drop shipping on amazon). I’ll put it myself in many days but will save money with your tutorials
EDIT : seen that one. Seems less expensive even if I deliver in France but no twillfast available only stayfast.
Old Feb 17, 2026 | 02:13 PM
pilegreatest's Avatar
pilegreatest
Originally Posted by Hocis
Hi everyone,
I’m having an issue with my new Nissan 350Z Roadster soft top. I am new in this world but love the car! When closing the roof, and after checking some Can Am accessories, the left side goes noticeably further down onto the windshield frame than the right side, which stops earlier. The result is an uneven fit when the top is fully closed, and from above, you can see that the fabric is not sitting symmetrically – it’s much flatter on the left, while the right side has the normal curve.
Your soft top is likely misaligned or unevenly tensioned. Check the frame, hinges, and side latches—small misadjustments can cause one side to sit lower and the fabric to stretch unevenly. A specialist can often realign or retension the top without needing a full replacement.
Old Feb 25, 2026 | 01:14 PM
pilegreatest
Hi everyone,
Also, I’ve noticed that where the soft top meets the windshield frame, especially at the corners, the new windshield is positioned slightly differently on the left side, making it look almost straight instead of having that slight downward curve that matches the frame. The right side still has the proper shape and curvature, which makes the issue even more obvious. A professional told me that the whole top would need to be replaced, which would cost several thousand euros.
Hi! What you’re experiencing is likely a soft top alignment issue, not necessarily a problem that requires full replacement. Often, the fabric tension or the roof frame is slightly off, causing one side to sit lower and the fit to appear uneven. A specialized convertible shop can usually adjust the frame and tension so both sides sit symmetrically. Before spending thousands on a new top, I would recommend having a soft top specialist check the alignment and tension. Many issues like yours can be corrected for a fraction of the cost. Make sure to show them photos from multiple angles to illustrate the asymmetry.
Old Mar 1, 2026 | 03:03 PM
Hocis's Avatar
Hocis
hello, thank you for answers, I will see with a professional in soft top to see that because the wind blows inside when I drive.
ahmad zeee
Feb 23, 2019 12:43 AM
BYL
Mar 31, 2008 07:49 PM
misel00
Feb 29, 2004 08:35 PM
N74DV
Mar 31, 2003 03:39 AM
