Locked in key, need help
Old Jun 7, 2004 | 11:59 PM
Globox's Avatar
Globox
Default Locked in key, need help
Yesterday evening I locked the car key of my ZR in the trunk. The other keys are at home, but home is 300 mls away.
Is there a secrete/hidden way to open the trunk ?
Nissan realy doesn't want to offer any assistance, I'm in Europe, they told me to call the number in my US manual and ask Nissan USA for help ....
Need help quickly because top is open and car is parked outdoors as Murphy predicted.
Thanks
Old Jun 8, 2004 | 12:06 AM
CaptinB's Avatar
CaptinB
If the Top is open, hit the unlock button on the door, then hit the trunk button that is Under the rear emblem, by the licence plate. You should feel a little rubber button. Pree it and that should open the trunk.
Haben sie ein gutes Tag!
Mien Deutch ist nicht gut. Ich habe zwei yahren Deutch.
CaptinB
Old Jun 8, 2004 | 03:35 AM
Globox's Avatar
Globox
Danke schön, Captin B
I tried, but unfortunately it did not work. I tried the single silver colored button in the door opener and the black central locking button, which opens/locks driver and passenger door simultaneously.
Any other ideas ?
Old Jun 8, 2004 | 04:48 AM
Dave Buswell's Avatar
Dave Buswell
Default Re: Locked in key, need help
Thanks
I believe the passenger seat will move forward using the button beside the center console on the passenger side even though there;s no key in the ignition. Once you can see behind the passenger seat there's an override switch that makes it impossible to open the trunk without your keyless remote. By moving the switch you'll then be able to open the trunk manually by pushing the rubber button under the Nissan emblem on the trunk lid.
Old Jun 8, 2004 | 05:02 AM
Globox's Avatar
Globox
Thanks Dave, I tried both positions of this button, but the trunk did not open.
I'll try tonite a combination of both ideas, the central lock key plus another position of the key behind the passenger seat.
I hope this will work.
Old Jun 8, 2004 | 08:00 PM
ohw's Avatar
ohw
try this:
Old Jun 8, 2004 | 08:03 PM
ohw's Avatar
ohw
ooops, picture didn't attach. Let me try again.
Old Jun 8, 2004 | 10:56 PM
Globox's Avatar
Globox
Thank you so much ohw, unfortunately my manual was also at home and my wife's English is not sufficient to read the manual.
Old Jun 9, 2004 | 10:04 AM
Zeenut's Avatar
Zeenut
Just a question. If your battery is dead and you need to get in the trunk through the rear box, how do you move the electric seat forward so that you can open the rear box and access the emergency trunk lid latch? Remember...dead battery. Thanks!
Old Jun 9, 2004 | 06:57 PM
ohw's Avatar
ohw
Hey Globox, no problem, glad to be able to help. There are lots to learn about this car. I keep my owner's manual in the car for situations like this.
How did you manage to lock your keys in the trunk? I can't figure out how that could happen.
Old Jun 9, 2004 | 07:41 PM
ragZ's Avatar
ragZ
I did the exact same thing today. other set of keys 2 hours away! Roof was off, windows down, hood open,alrm on. I reached in and tried the unlock button, worked on doors not trunk. open doors alarm goes off. I had just installed nav-tv with dvd player in lock box behind passenger seat with owners manual also inside and thats now kept locked since install, so I'm screwed!!
What I did was I said screw it and was able to pull the forcably pull the box open !! No damage caused (few) once I got the manual it was a piece of cake.
Like in the drawing a few threads up. once you get the box open there is a small cover, if you don't look hard you won't see it.removethe cover ,pull the tab and walla, the trunks is open!!! Hello Keys!!!!
Old Jun 9, 2004 | 11:12 PM
Globox's Avatar
Globox
@ ohw
that was an easy one:
open trunk with third button on remote control, which only opens trunk, put your key in trunk, close trunk, and you're screwed.
Next time I'll probably remember:
If everything else fails, read the instructions. (Murphy)
BTW: I have a very early 2004 roadster (built Sept 2003) VIN 4205, now 3500 mls, no tire feathering at all. I am used to drive with a comparatively high tire pressure (2,8 bar, approx 40 psi), which gives a better cornering, a little less comfort on bumpy roads, and a better mileage (gas over here about USD 5,50 per gallon) and probably no tire feathering. I do this since years with all sorts of cars without any problems.
Old Jun 10, 2004 | 02:01 PM
ohw's Avatar
ohw
Thanks Globox. I just tried what you described, sure enough, trunk is locked. Guess I've never done that, yet.
With 40 psi in the tires, you may get more wear around the center of the tires over long period. If you corner hard all the time, the outside edge of the front tires will wear out fast. I did autoX for about 20 years. Most of my previous vehicles had -ve camber in the front which wore out the inside edge. All three gave me even wear, sort of.
Zeenut, you are right about the dead battery. I think in such a case, we're SOL. I wonder if the batt is dead, unlocking the passenger door with the key would unlock the trunk?
GagZ, how long did it take before the alarm shut itself off? If at all?
Old Jun 10, 2004 | 02:15 PM
ragZ's Avatar
ragZ
ragz not gagz (but thats pretty funny!!) The alarm shut off in a couple of minutes(thank goodness) its pretty loud!!
Old Jun 10, 2004 | 02:19 PM
ohw's Avatar
ohw
Sorry ragZ, tigger finger too fast!!
Old Jun 11, 2004 | 04:08 AM
Globox's Avatar
Globox
ohw, I hope you had a second set of keys at hand when you closed the trunk.
Old Jun 11, 2004 | 10:45 AM
ohw's Avatar
ohw
HaHaHa, I didn't have a second set of keys at the time. but I kept the keys in my pocket before shutting the trunk lid.
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Ganglio
Europe
Sep 26, 2015 07:06 PM
