Oil Pressure
Old Aug 17, 2004 | 10:51 AM
Penderwheels's Avatar
Penderwheels
Question Oil Pressure
'04 Roadster built 6/04, 500 miles. 6mt.
After engine warms up, my idling oil pressure reads below 30 psi. (assuming the first un-marked tic mark on the gauge is 30 psi.)
Running pressure (2000-3500 rpm) is between 60-90 psi.
I'm surprised the pressure is so low on a new engine. I expect it will be about 10 psi less when nicely broken in (1500-2000 mi). Thus it will be only about 20 psi at idle. Does this seem too low???
What's your oil pressure at idle?
Thanx........
Old Aug 17, 2004 | 12:52 PM
ZxRage's Avatar
ZxRage
When I start up in the morning it can bury at 120 psi. I don't know why but I will find out soon. Around 2000 rpm, it is at 60 psi or above. I don't know what it is at idle, I don't sit still for very long.
Old Aug 17, 2004 | 05:42 PM
elyliu's Avatar
elyliu
my is at about the same....
Old Aug 18, 2004 | 02:14 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Just for the hell of it I checked the Oil pressure as I was sitting in traffice tonight. Assuming the first tick mark is 30 PSI then at Idle it's about 15 PSI
Old Aug 19, 2004 | 09:35 AM
Darren's Avatar
Darren
Those numbers sound pretty typical of this engine. Remember too that your numbers will be slightly higher for a period after an oil change and will decrease as the oil viscosity breaks down.
Old Aug 19, 2004 | 12:20 PM
orionflyer20's Avatar
orionflyer20
Referencing the Service manual for oil pump output at certain rpm's:
ENGINE RPM: APPROXIMATE DISCHARGE PRESS (kPa):
(kg/cm2, psi)
Idle more than 98 (1.0, 14)
2,000 more than 294 (3.0, 43)
6,000 more thab 392 (4.0, 57)
Penderwheels, it seems that your car is well within standards according to the service manual. By the way, if you have the manual you can reference page LU-14. Hope this helps!
Old Aug 19, 2004 | 01:02 PM
Penderwheels
Thanx, Oh Rion Yes, got the manual. never thought to look
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
