370Z Brakes & Suspension 370Z stoppers, coils, shocks/dampers
Inexpensive Brake Upgrade: Agency Power Brake Lines
Old Feb 24, 2011 | 01:20 PM
Agency-Power's Avatar
Agency-Power
Vendor - Former Vendor
Default Inexpensive Brake Upgrade: Agency Power Brake Lines
If you're looking for a great bang for the buck brake system upgrade or addition, check out the Agency Power Steel Braided Brake Lines.
Agency Power now has a wide variety of steel braided brake line and clutch line kits for most high-end performance cars. The brake line and clutch line kits are made in the USA to meet strict D.O.T. certifications. The steel braided lines are a red color with the AP logo printed on it. The CNC machined fittings are in classic Agency Power plated black to separate you from the competition. All kits are assembled for a quick and easy install. Including fittings, hoses, and necessary hardware.
Steel Braided lines improve component performance over the stock rubber hose. With rubber hose, the fluid under pressure flexes the hose, causing loss in firmness and reaction. With the steel braided lines, the response is firmer giving you more control.
Brake lines are sold as a pair and are designed to work with the OEM brake system. Special applications available upon request.
All Agency Power products come with a limted lifetime warranty.
<object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/9xQZu__xbbo?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/9xQZu__xbbo?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></object>
