370Z Exterior & Interior 370Z body kits, exterior modification, interior styling and lighting
Sponsored by:
Sponsored by: CARiD
EVO-R fog light install HELP
Old Apr 22, 2012 | 10:37 AM
gy954's Avatar
gy954
Default EVO-R fog light install HELP
For those who have done this, please pat me on the head and tell me it will be alright....
I am installing the EVO-R fog light on my 370Z.
Please confirm that the only thing that holds the light onto the car is the double-sided tape.
I find it hard to believe that the tape does the work of the two bolts on the old dummy housing (which is discarded?).
Really? I need to be told it won't fall off when I hit a bump somewhere.
TIA. / Greg
Old Apr 22, 2012 | 04:54 PM
JCITY's Avatar
JCITY
I've not seen this kit.However,the use of 3-M tape if done correctly is pretty damn strong.Rear spoilers are installed all the time with 3-m.
Make sure the surface is clean(use rubbing alcohol).Remove the red backing. Heat up the tape surface and the surface
you are applying the part to with a hair dryer.Press it on hard.You are done...
Old Apr 22, 2012 | 07:26 PM
gy954's Avatar
gy954
Default Thanks, JCITY, that's EXACTLY what I wanted! (nt)
This board's software doesn't take empty messages?! I guess using "nt" in the title is useless then.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
