Dual amp installation?
Old Dec 3, 2004 | 09:38 PM
RedBird's Avatar
RedBird
Default Dual amp installation?
I know that many people are installing an amp in the compartment behind the front seat, but where can I install the second amp? I want to run 2 10" woofers in the rear under the strut tower off one amp and the front speakers off the second one, and let the 2 rear amps behind the seats run off the head unit.
Old Dec 3, 2004 | 11:11 PM
Zenvy's Avatar
Zenvy
Default Re: Dual amp installation?
good question! anyone?(under the seat?)
Old Dec 4, 2004 | 12:01 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
put em both back there?
the only problem with that is heat... it will be fine if your amps have fans built into them but if not the solution is a simple set of 12v computer fans which serve to move air around that compartment.
Old Dec 4, 2004 | 12:57 AM
Z-INCOGNITO's Avatar
Z-INCOGNITO
i have 2 amps in my compartment (behind the driver seat) and no heat problems so far...
Old Dec 5, 2004 | 07:40 PM
cehome's Avatar
cehome
I placed one amp in the glove box (behing passenger seat) and the other in the compartment behind the driver seat. No heat issues for me either.
Old Dec 6, 2004 | 01:29 AM
jreiter's Avatar
jreiter
Or you can put them both (including the sub) in the spare tire well. (As long as you don't mind losing the spare.)
Click on my sig to see other pics.
Old Dec 6, 2004 | 06:47 AM
LS350Z's Avatar
LS350Z
Charter Member #56
Mine's similar to rieters but my sub is closest to the back for better respone. I have enough room in the amp area to add 2 more XTANT X series amps if I like .
That picture is old as **** and the amp is the only thing that looks almost the same - lol. I've since added a big area of carbon fiber around the sub, I'm showing off my Boston Z6 crossovers, and leds and other rice stuff. As I said though, I can add 2 more amps where my current one is.
Old Dec 6, 2004 | 07:47 AM
motown's Avatar
motown
i have 3 amps in the 'bose compartment' behind the drivers seat. plenty of room back there. ahsmo's right about the cooling though, you'll need a fan for any amps that generate excessive heat.
Old Dec 6, 2004 | 09:13 AM
MIAPLAYA's Avatar
MIAPLAYA
I have two amps behind my drivers seat no problem...
Old Dec 6, 2004 | 04:45 PM
nissan_fanatic's Avatar
nissan_fanatic
If you don't care about your spare there is plenty of room in the trunk
Old Dec 6, 2004 | 04:53 PM
done12many2's Avatar
done12many2
I have one of my Zapco amps and a JL Audio 1000/1 in the compartment behind the driver's seat and have not experienced any heat issues.
Old Dec 6, 2004 | 06:17 PM
RedBird's Avatar
RedBird
For you people who have both amps in the same compartment behind the seats, do you still have the door to the compartment on or have you taken it off for air circulation.
Old Dec 6, 2004 | 06:22 PM
zcat59's Avatar
zcat59
I have JL 300/4 & JL 250/1 in the compartment behind the drivers seat. The cover already has holes from the old bose woofer. The amps seem to stay cool enough.
Old Dec 6, 2004 | 06:26 PM
04_CS_Z33's Avatar
04_CS_Z33
No problems with 2 amps in the compartment behind drivers seat.
Old Dec 7, 2004 | 01:15 PM
RedBird's Avatar
RedBird
I can't tell if you still have the door for that compartment still on there, I was interested in wether you took it off for the amps to get circulation or you left it on to close the compartment when the seat is back up.
Old Dec 7, 2004 | 02:05 PM
MIAPLAYA's Avatar
MIAPLAYA
I have the solid no speaker panel on with no issues....
Old Dec 7, 2004 | 02:16 PM
jreiter's Avatar
jreiter
In my install I have the amps covered in a sealed area, and they don't overheat at all. I think it really depends on how much power you plan to pump out and how hot your amps get. What I've seen many people do in that area behind the driver is get the oem Bose subwoofer grill panel instead of the solid panel. This at least gives that area some holes to ventilate through, and it should just snap right on.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
