HELP: My dash panel won't light up and my headunit won't work.
Old Dec 14, 2004 | 09:50 PM
chaofun's Avatar
chaofun
Default HELP: My dash panel won't light up and my headunit won't work.
Help. I was in the middle of installing my headunit, and then the headunit shut off. I couldn't turn it back on. I notice that my dash lights won't go on. Did I short circuit something? Does anyone know what to do???
Old Dec 14, 2004 | 10:22 PM
eMpTei's Avatar
eMpTei
Did you check the connection to the guages on top?, if that's not it, it might be a blown fuse
Old Dec 15, 2004 | 08:45 AM
alininger2001's Avatar
alininger2001
Ditto on that one.
Old Dec 16, 2004 | 03:31 AM
Barzten1's Avatar
Barzten1
Probably a fuse!
Old Dec 16, 2004 | 10:04 AM
motown's Avatar
motown
fuse panel's in the drivers kick panel. you prob. blew the fuse out.
Old Dec 16, 2004 | 09:00 PM
chaofun's Avatar
chaofun
Thanks for the help so far guys. How do I locate which fuse is blown?
Old Dec 16, 2004 | 09:07 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
negative...the fuse for the radio and stuff is under the hood next to the battery, I happen to know x)
Old Dec 16, 2004 | 09:09 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
look at the long plastic box, on top is a diagram of the fuses... look for the "acc" fuse or Radio fuse I dont remember which one it is exactly
Old Dec 16, 2004 | 09:22 PM
chaofun's Avatar
chaofun
Does anyone have a picture of the fuse box?
Old Dec 17, 2004 | 11:36 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
You don't need one. The lid of the fuse box has a diagram that tells you what is what.
Old Dec 17, 2004 | 07:35 PM
chaofun's Avatar
chaofun
Ok. I've found the fuse box, and opened it up. How do you take out the fuse?? It feels like it's really stuck in there. It hurts my fingers trying to squeeze in there and pull.
Also, does Nissan give me spare fuses? Where are they if they do?
Old Dec 17, 2004 | 07:54 PM
bastard's Avatar
bastard
Okay, there's two fuse boxes on the 350z for the stereo. The constant hot (clock/preset saving) lead fuse is by the battery in that little plastic fusebox in there. The ignition hot fuse is in the driver's side kickpanel.
There should be a fuse puller somewhere. It's likely it's in the kickpanel with the other fusebox. You can probably buy the fuses at pep boys or a place like that.
Uriyo_
Sep 8, 2021 08:46 AM
dcains
Nov 11, 2015 11:36 PM
samansharif
Sep 25, 2015 12:31 PM
