Is this a good sub enclosure?
Old Dec 18, 2004 | 03:07 PM
robcassell's Avatar
robcassell
Default Is this a good sub enclosure?
I am wondering if you all think this box would suffice to put a 10" JL sub in and do you think if it will fit in the compartment behind the driver?
Suggestions needed!!
Enclosure
Old Dec 18, 2004 | 03:44 PM
tractng's Avatar
tractng
robcassell,
It wouldn't fit. The max. height for the stock opening is around 8.5 inches. So your box should be 7.5 - 8.0 high. The woofer will add another .50- .75 inch to the total measurement.
I built like 3 boxes so far so I know the measurements.
Let me know if you have any questions.
Tony
Old Dec 18, 2004 | 07:11 PM
the7ferret's Avatar
the7ferret
i agree with tracting, best bet if you want it behind the driver seat is to get all the stuff that you need to mount the factory sub, then seal off the inside of the compartment with silicone, and dynamat(or similar) and mount the sub in there, Lots of ppl have done it with great sucess. If you wanna be real trick you can coat the inside with fiberglass, paint it, put on a lexan window and mount the sub to the window and put a light in the compartment and be pimp..
Old Dec 18, 2004 | 09:55 PM
tractng's Avatar
tractng
robcassell,
How about something like this?
It is fiberglass.
Tony
Old Dec 19, 2004 | 07:23 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Anyone do this with a roadster? I'm wondering if there is the same space in there as the coupe.
Jambo016
Sep 16, 2016 01:08 PM
