Kenwood DDX 7015 Install
Old Feb 9, 2005 | 07:00 AM
Fazio239's Avatar
Fazio239
Default Kenwood DDX 7015 Install
I'm New to the site. Anyone got any install tips on the ddx7015.
More specfically where to ground the parking brake wire, and where to tap for power under the dash. Thanks ahead of time for the help
Old Feb 9, 2005 | 09:54 AM
gundam02's Avatar
gundam02
Get the Metra wiring kit for the 350Z (available pretty much anywhere that installs stereos). It will have all applicable wires.
Only thing, don't hook up the luminance wire, there have been issues with it (I had one HU die).
As far as the ground, you can just splice into the stereo ground. So you will have 2 ground wires out of the radio into the single for the car.
Mine works great.
Old Feb 9, 2005 | 10:07 AM
Fazio239's Avatar
Fazio239
Hey Thanks for the help... I would have hooked up the LUM. wire for sure. Any idea's on where to tap power for the brake switch harness.
Old Feb 9, 2005 | 12:19 PM
gundam02's Avatar
gundam02
Oh, you got me on that one.
It's been a while since I installed mine. I will have to look at the instruction manual and see. But I think I spliced all the power and ground into the same connectors.
Old Feb 11, 2005 | 03:50 AM
35oZephyR's Avatar
35oZephyR
Will be installing the same HU soon.
There use to be some good install threads on these forums but alot of the links with pictures are dead.
Old Feb 11, 2005 | 05:07 AM
Fazio239's Avatar
Fazio239
Same here. Installing it this weekend. There are good instructions to disassemble the dash, but as far as installation nothing specific. Here are some good disassembly instructions.DASH
Old Feb 13, 2005 | 08:44 PM
DaTaSPiKe's Avatar
DaTaSPiKe
I DO NOT check this board regularly, but if you have any questions, drop me an e-mail.
Here are some pictures of the wire harness.
Chris
Old Feb 14, 2005 | 04:03 AM
Fazio239's Avatar
Fazio239
Thanks for everyones help. Installed this weekend, works great. Pics Coming soon. Anyone using the stock speakers with this HU?I got a question about the EQ......... Seems like I have a lack of sub with the new deck as compared to the Stock Deck.
Old Feb 14, 2005 | 05:14 AM
mcduck's Avatar
mcduck
recently did this install. There is a lot more information at the other 350Z site that seems to be censored here for no good reason whatsoever. To go directly to one of my more detailed threads on DDX7015 install go to (just replace the "####" in the line below with "-" )....
http://www.350z####tech.com/forums/i...opic=3048&st=0
dcains
Nov 11, 2015 11:36 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
