Boston Pro60 Component Install
Old Feb 27, 2005 | 08:37 PM
Steve_TexasZ's Avatar
Steve_TexasZ
Default Boston Pro60 Component Install
I finished installing my new Boston Pro60 components. The install was pretty easy, they fit great in the 350z, and they sound amazing. Sorry--no pics.
I used 1" Metra spacers for the woofers. Just mounted the spacer to the door with the hardware that came with the spacer. Then I screwed the woofers into the spacers. Didn't need to drill any new holes. Fit great and very tight. The woofers clear the window just fine.
I installed the Boston tweeters in the stock tweeter location. This took some more work. I used a dremel to clean up the back of the triangle shaped panel, then I used a 1 3/4" hole saw to cut the holes to flush mount the tweeters. Hot glue gunned the tweeters from the back of the panel, and they hold great.
The Boston crossovers are kinda big, but I was able to install them inside the door panels and attached them with heavy duty velcro. I put them just behind the wiring grommet in the door. I had to cut a rib from the door panel to allow enough clearance.
These are excellent component speakers and a huge improvement over the crappy stock bose speakers. I'm running a Xtant 2.2 to them and they pump out lots of mid bass and silky highs. Highly recommended for the 350z.
My next steps--dynamat inside the door panels and upgrade from the stock speaker wire.
Old Feb 27, 2005 | 09:07 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
sounds like a good set up...
I would like to get my hands on an Xtant amp some day.....
Old Feb 28, 2005 | 10:08 AM
motown's Avatar
motown
great choice with the BA speakers! if you're anything like me, these will outlast any car you own. i've had my set for almost 10 years now and still love the way they sound. hey, on an unrelated note, how do you like your Ultimate cat's? i've been thinking of upgrading to these, but haven't heard much about them. u'r opinion?
thanks!
Old Feb 28, 2005 | 03:01 PM
Steve_TexasZ
thanks!
I love the BAs and the UR cats too. The UR cats were a perfect fit and no check engine light errors.
Old Feb 28, 2005 | 09:45 PM
stu46's Avatar
stu46
Awesome setup.
Old Feb 28, 2005 | 09:46 PM
stu46's Avatar
stu46
If you're ever in Hawaii, let me know. You can listen to all 6 of mine.
Old Mar 1, 2005 | 09:04 PM
05-Z's Avatar
05-Z
Just wait until you get dynamat and some 16awg speakerwire in there....great speakers.
Old Mar 1, 2005 | 09:14 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
you will be the first to know im in the area heh
Old Mar 3, 2005 | 04:25 AM
LS350Z's Avatar
LS350Z
Charter Member #56
Awesome choice!!! The only Boston Pro speaker I haven't bought yet is the Pro60s. I've got all the other series dating back to the original like in 1994....
Anyway - dynamat the **** out of the doors, especially right behind the speaker.
Old Mar 5, 2005 | 02:28 PM
Steve_TexasZ
I finished the dynamat today and it came great. I installed regular dynamat on the inside of the door panels and under the strut bar cover to get rid of some vibrations. It took a couple of hours to put it in, but it's well worth it. Really cleaned up the sound.
Old Mar 7, 2005 | 01:10 PM
LS350Z's Avatar
LS350Z
Charter Member #56
Did you triple layer behind the front speakers. If not I highly recommend it for better front mid response. Again - great choice in component speakers. And if you think the Pro60 crossovers are big - check out the Reference Z6 crossovers - they are massive!
Old Mar 27, 2005 | 08:14 PM
cure20's Avatar
cure20
i have the same exact set up as you. except i already installed the dynomat. sounds great.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
