SES light On
Old Mar 1, 2005 | 08:36 PM
tractng's Avatar
tractng
Default SES light On
Guys,
Any links as to where i can find a procedure to turn it off. This hapens when i installed my stereo a few months ago. I took out the ribbon behind the stock unit.
Btw, I did removed the negative battery terminal before doing it, but the light still goes on.
Some guy posted this, but i have no luck. My is "Service Engine Soon". Are they the same?
Tony
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures for Basic reset.
with M/T depress clutch and hold it in.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Tony
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
