system help please
Old Mar 28, 2005 | 03:42 PM
03_Track_Z's Avatar
03_Track_Z
Default system help please
Hey I think I know what I want to do as far as subs now. I want to run 2 Audiobahn ALUM8P 8" woofers, one behind each seat. I want to stick one in the glove box and one in the factory sub housing (I do not have the factory sub, didn't get the Bose). Is this possible? How would I go about doing it and how much would it cost? Just walk me through the basics please. Thanks.
Old Mar 28, 2005 | 04:42 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Here is a link to a site that sells the metal brackets to mount 10" subs. You could make some sort of plate/box so the 8" subs would mount up in the ten inch hole. They also sell the bose covers($10.17). From what I understand you can remove the glove box and these parts will fit on the passenger side also.
http://www.courtesyparts.com/350z/interior.html
Old Mar 29, 2005 | 05:48 AM
hjobe's Avatar
hjobe
Does anyone have any instructions on how to replace the glove box door with the bose speaker grille!?!?!?!?!
Old Mar 29, 2005 | 06:03 AM
Daewoo's Avatar
Daewoo
I think it just pops in.
Old Mar 29, 2005 | 06:07 AM
hjobe's Avatar
hjobe
Just by looking at it, the glove box plastic housing does not have the same holes for the tabs on the bose speaker. Also, I can't even see how the glove box door pops off.
DIY PLEASE!!!!!!!!!!!!!!!
Old Mar 29, 2005 | 09:43 AM
Zivman's Avatar
Zivman
There are better subs out there for less $.
And the box is EASY to remove. Just pop the back panel off and the door comes with it. Unscrew the glove box and replace it with the bose cover.
Old Mar 29, 2005 | 09:56 AM
hjobe's Avatar
hjobe
I am pretty bad with this kind of stuff. Does anyone have pics of replacing the glove box with the bose speaker panel?
Old Mar 29, 2005 | 01:54 PM
03_Track_Z's Avatar
03_Track_Z
I don't see how the bracket that goes on the right side for the factory woofer would fit on the left side, they don't look to be the same. Is there anyone who has actually done it that can verify this before I go and buy 2 brackets? Thanks.
Old Mar 29, 2005 | 02:01 PM
Zivman's Avatar
Zivman
there are many who have done this. I just had my car ripped apart for my stereo install and from what I could see, the two openings are identical. just take the bose cover off the driver's side and see if it lines up.
Old Mar 29, 2005 | 02:21 PM
hjobe's Avatar
hjobe
Does anyone have any instructions on how you go about removing the glove box door?
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
