Thoughts Audio experts on this setup??
Old Apr 3, 2005 | 09:05 AM
Chief F1 Fan's Avatar
Chief F1 Fan
Default Thoughts Audio experts on this setup??
I'm thinking of the using the following components in my 04 ZR
Alpine 9820xm
Focal 165k2p's
JL 300/4
subwoofer?
What do you guys think? I really want xm w/o all the ancillary pieces in my car as space is at a premium. Any help would be greatly appreciated. thanks
Old Apr 3, 2005 | 11:24 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Don't worry about all the little pieces. They all fit very nicely in the compartment behind the driver seat. I also have a roadster and wanted to keep as much space as possible. I think I found the perfect compromise between sound and space. My trunk has a sub and 5ch. amp in it. Over the summer I'm going to set them into the spare tire well and will have my full trunk back. Don't worry about space too much. If you don't mind taking your spare tire out then you can put everything down there and keep all your trunk space.
Old Apr 3, 2005 | 11:25 AM
Andys'Z's Avatar
Andys'Z
ditto on the focals and jl combination.. subwoofer choice will effect your system a lot though, listen to subs everybody has a different taste, however if you are a focal/jl fan like me you should go with a focal or JL sub. I have 12w6v2 for now however if I wouldent have it I would probably get a focal sub too, when I listend to to it Jl seemed to hit harder however focal was very audible, smooth and clean on lower frequencies.
Old Apr 3, 2005 | 11:46 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Alpine 9820xm
Focal 165k2p's
JL 300/4
subwoofer?
Looks good, what are planning on paying for the JL amp?
What kind of music do you listen to?
Old Apr 3, 2005 | 03:05 PM
Chief F1 Fan
I listen to rock, classical, jazz, reggae, and country (only when wifey is in the car). What sub should I look at? Like Santacruz sez, a Focal? I don't know what I'm going to end up paying for JL but I've heard great things about it, heard it played and like it. You guys think I need 2 sets of 165k2p's as well or can the stock speakers be used to fill in? Santaruz, I will do the spare tire thing as well, like you intimate, why do you need the spare anyways? I don't. If it goes flat, call a flatbed.
Old Apr 3, 2005 | 09:59 PM
BoostTed's Avatar
BoostTed
dont bother with rear speakers. Im running a 3 way focal setup up front and the sound is amazing. Id get a JL 300/2 to power the front instead of the 300/4 if you are going to do just the front speakers. With your taste in music I'd go with a sub that has more SQ vs one that has more bass.
Old Apr 4, 2005 | 08:25 AM
Chief F1 Fan
OK, for the noob on this stuff, which sub would you recommend to fit your criteria (SQ)BoostTed?
Old Apr 5, 2005 | 07:12 PM
BoostTed's Avatar
BoostTed
I like Diamond Audio subs Ive had the M5 and the Hex line and was very happy with them. Those lines are discontinued but I believe they have like a D6 line. Also check out Image Dynamics. Focal subs are very nice as well, i may swap out to a focal sub soon.
Old Apr 6, 2005 | 05:05 PM
Tackett's Avatar
Tackett
could always go with Vega. I love the hell out of mine and Ive had it for years.
If you really want to spend the cash you could go with a Stroker Pro, though you would have to get a box custom fit to use your entire freakin hatch space, those things need crazy airspace.
Old Apr 7, 2005 | 10:02 PM
juyz's Avatar
juyz
I recomment the Image Dynamics IDMAX 10" version 3
This is a very good sound quality subwoofer. $399 ea.
http://www.cardomain.com/item/IDSIDMAX10V3D4
http://www.imagedynamicsusa.com/webs...cts/index.html
Another sq sub i like are the focal subs. This is what my friend
uses to compete.
Focal 33KX http://www.focal-america.com/catalog...ower/33kx.html
Old Apr 8, 2005 | 05:50 AM
Faikius's Avatar
Faikius
uses to compete.
Keep in mind he'd probably want to use a much more powerful amp with an IDMAX 10''....I've seen quite a few people pair that with a JL 1000/1
Old Apr 8, 2005 | 06:47 AM
Chief F1 Fan
I'll likely stick w/ Focal sub, 165k2p's up front only, possibly a 9835 h/u from Alpine, still unsure.
Old Apr 8, 2005 | 06:48 AM
Chief F1 Fan
whoops, meant to say will the JL 300/4 still be a wise choice? I can get it for $349.
Old Apr 8, 2005 | 08:21 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Id say a http://www.cardomain.com/item/PHOX2004 200.4 and have plenty of power for a little bit more money.
Its a stout amp.
Old Apr 8, 2005 | 09:10 AM
juyz's Avatar
juyz
Its a stout amp.
Man those phoenix gold are a steal, i wonder why their on sale at
sound domain. But specs looks good 200 x 2 to the front, 400 w bridged
to your focal sub. The 27kx can handle 300w rms - 600 max.
Old Apr 8, 2005 | 01:49 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
They are making a little over 10% on those amps. So yes a steal indeed.
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
