Need suggestions on power inverter for ps2...
Old Apr 22, 2005 | 06:42 AM
solidsnake's Avatar
solidsnake
Default Need suggestions on power inverter for ps2...
OK I got the screen, radio and playstation hooked up. I go and power up the inverter and all I hear is a buzzing sound from the speakers. The audio works but it is distorted like crazy. I put the converter on the passanger side near the speaker. Is that what is causiing my problem. Is the location of the power effect the audio? Do I need a filter or to just relocate? Here Is what I have hookep up. Alpine 9851 I think, PS2 and farenheit 7001 screen. Help me get rid of the distortion.
Old Apr 22, 2005 | 08:22 PM
microsteve40's Avatar
microsteve40
Know it all
My power converter is mounted under the glove box, under that little panel that comes off. I haven't had any noise problems at all with my setup.
Old Apr 22, 2005 | 10:30 PM
solidsnake's Avatar
solidsnake
You think that it may be cause by the location of the PS2? I heard that it may cause problems if too close to speakers or headunit
Old Apr 23, 2005 | 08:36 AM
BoostTed's Avatar
BoostTed
how are you wireing the invertor? Just plugging it through the cig lighter or hardwireing it?
Old Apr 24, 2005 | 08:43 PM
solidsnake's Avatar
solidsnake
From what ive been told. The PS2 is what may be causing the problemo due to its location. The inverter is hooked and powered by the battery.
Old Apr 24, 2005 | 10:15 PM
supsup's Avatar
supsup
Newbie
yeah i am about to do the ps2 thing too
i got a inverter ...so i am not suppose to hook it up to the cig lighter?
how to wire it stright from the battery?
some ppl say i need a filter or something....but where can i get it?
what is it?
thanks
Old Apr 24, 2005 | 10:19 PM
solidsnake's Avatar
solidsnake
I was told the same about the filter..can someone that has done this answer the questions.. ANyone have install pics?
Old Apr 24, 2005 | 10:20 PM
BoostTed's Avatar
BoostTed
unplug the PS2 and just turn on the invertor by it self. If its still there the invertor is the issue if its not then the PS2 is the issue. Where is the PS2 located?
Old Apr 24, 2005 | 10:22 PM
BoostTed's Avatar
BoostTed
i have my invertor wired to the battery and the PS2 plugs into the invertor...no filters.
Old Apr 24, 2005 | 10:36 PM
solidsnake's Avatar
solidsnake
ps2 is right under where the glove box would be..is right below the cig ligther in front of the passanger seat.
Old Apr 24, 2005 | 10:47 PM
solidsnake's Avatar
solidsnake
Got pics BoostTed?
Old Apr 24, 2005 | 10:48 PM
BoostTed's Avatar
BoostTed
ive had it there before in previous cars. Try swapping out with a differnet brand invertors. My uncle had an issue with his invertor it caused some buzzing, it ended up just being a cheap invertor. The filter everyone says to use is a ground loop filter.
Old Apr 24, 2005 | 11:02 PM
BoostTed's Avatar
BoostTed
Got pics BoostTed?
pics of the wireing? no dont have pics of that.
Old Apr 25, 2005 | 07:55 AM
maxipad96's Avatar
maxipad96
Most likely its the inverter. I'm having the same issue powering my cpu. A good test is run an extension cord to your car and hook up the playstation to regular power. No Buzz... then you've found the problem. I've heard some inverters are better than others. I've heard that the Coleman product is excellent - No buzz.
Old Apr 25, 2005 | 12:07 PM
solidsnake's Avatar
solidsnake
Which inverter do you have boost? Ill buy that one!
Old Apr 25, 2005 | 05:08 PM
BoostTed's Avatar
BoostTed
im using this one
http://www.radioshack.com/product.as...%5Fid=22%2D146
Old Apr 25, 2005 | 06:12 PM
supsup's Avatar
supsup
Newbie
what if i can't refund the one i have now...
what filter do i need?
Old Apr 25, 2005 | 06:17 PM
BoostTed's Avatar
BoostTed
a ground loop filter, give that a try
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Apr 26, 2005 | 12:59 AM
MySunset350Z's Avatar
MySunset350Z
walk into radio shack and tell them i need a 10amp power filter to be used in a car. its like $15. the cig ligher isnt a great place to tap into. there are a bunch of other circuits running off it and you will end up with a lot of noise and interference. run it straight off the battery and make sure you have use a thick ground wire grounded to good spot on the car.
and inveter with some sort of noise filtration is another good way. spend the extra bucks on a good inverter.
codek
Sep 28, 2015 03:03 AM
