Insalling Sub on a new Z
Old May 19, 2005 | 04:16 AM
PHANMAN's Avatar
PHANMAN
Default Insalling Sub on a new Z
I just got my Z. It is a base model. It did not come with a sub. I like to install a sub into the factory location. Can I just install and connect a sub and it will work? If so...does anyone have a picture of where to connect the sub to?
Thanks,
Phan
Old May 19, 2005 | 05:23 AM
isugoo's Avatar
isugoo
if you're not planning to put a box, you will need to use free air sub only.
i'm still having hard time deciding putting the box on the trunk or adding free air sub in the stock location.
people says it sounds better with box but i really don't want to spend my trunk for this since its only car i have...
only free-air sub i know is infinity perfect 10.1d you can check it out from crutchfield website and you will find a definition of free-air sub there too. (in case you're not familiar with that term)
Old May 19, 2005 | 08:53 AM
PHANMAN's Avatar
PHANMAN
Just got back from the local electronics store. I am scheduled to have the sub installed today. They are going to install a 10" Kicker free air sub into the stock location. They also will fill the enclosure with some material to get better sound. They will also install a small 60x2 amp to push the sub. With all the kits and components needed, this will cost $325.00. I'll let everyone know how it sounds.
Hope this will make the music sounds decent...I've taken a vacation day from work for this.
Phan
Old May 19, 2005 | 09:49 AM
ANXIOUZ's Avatar
ANXIOUZ
Definitely let us know.
I looked into fre air's and there was a nice alluminum 10" by Eclipse that I sampled. I think it was $119.
Old May 19, 2005 | 03:48 PM
PHANMAN's Avatar
PHANMAN
OK...it is installed. Here's the verdict:
Component Installed:
- HLC $25
- Kicker C10 10" Sub $60
- Tsunami Speaker Kit $15
- Amp Wire $40
- Vortex 602 amp 60x2 $85
- Installation $100
- (2) high quality pillows
I now have BASS. The system sounds 20x better and the sub throws more than enough bass for my taste...I listen to melow rock music. The pillows were used to stuff the cavity and all open holes were covered with some type of metallic foam tape. The amp was placed in the storage compartment behind the passenger seat. Everything is neatly hidden away. I will order a sub cover for this...Its like less than $15. Once the sub cover is installed, everything will look like factory.
BTW...the sub does vibrate the driver seat...it would have been better to have the sub installed behind the passenger seat. Anyway...this is a cheap and affective way to get some decent bass for the Z.
Phan
Old May 20, 2005 | 08:39 AM
ANXIOUZ's Avatar
ANXIOUZ
Cool. So you're still using the factory deck? And do the pillows help the sound quality of do they help stop rattles?
Old May 20, 2005 | 05:11 PM
PHANMAN's Avatar
PHANMAN
Still using the factory deck. Didn't see the need to spend more dollars. Th pillows filled the cavity...I don't know if it improved the sound quailty. I haven't heard any rattles...yet...it just fills funny...vibrating my back and butt.
Old Sep 30, 2005 | 08:34 PM
Boomer350Z's Avatar
Boomer350Z
Default Any Pics?
Hey Phan:
Any rattles yet? How does it look with the cover?
Do you have some pics that you can post...
Thanks!
Old Oct 1, 2005 | 07:18 AM
james840a's Avatar
james840a
isugoo, if your worried about trunk space you could go my route. See the link to the pictures i have.
https://my350z.com/forum/audio-and-video/145065-my-redesign-audio-install.html
Old Oct 1, 2005 | 09:19 AM
ANXIOUZ's Avatar
ANXIOUZ
Very nice James.
Old Oct 2, 2005 | 06:03 PM
lakez34's Avatar
lakez34
I'm kind of interested to know as well. I'm considering getting the same type of setup, but I'm concerned about rattles and the like. I don't know if Dynamat alone will absorb it.
Old Oct 27, 2005 | 07:57 AM
stevenkseward's Avatar
stevenkseward
Hey you say that you wished the sub was behind the passenger seat. I haven't really checked it out in much detail, but could you just switch the amp and the sub? I don't want to be sitting on a vibrator while I drive.
KingWiz24
Jul 13, 2013 11:37 AM
hellsoldiers08
Nov 1, 2012 05:57 AM
S&R Performance
Suspension
13
Sep 21, 2011 10:55 AM
rich2342
Apr 15, 2011 12:59 PM
dklau33
May 27, 2006 01:34 AM
