help getting a humming sound from my speaker
Old May 29, 2005 | 05:58 PM
ivory_g35's Avatar
ivory_g35
Default help getting a humming sound from my speaker
Hi just finsh install my amp now i'm getting this humming sound coming out of the speakers and it gets louder as i rev. i think i could be the ground connection. At the moment i only have it grounded to a point in the trunk. do i need to run the ground back to the batt?
thanks
Old May 29, 2005 | 07:47 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Does the frequency change with the speed of the engine? If so you have alternator whine and need a "choke coil" installed in series with the (+) power line. It needs to be big enough to supply enough current (amps) to your power amp. They're not that expensive.
Normally one good ground is enough. The key is a good ground - make sure the paint is scraped free from the area and that the screw and termimal/bare wire is very tight.
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
