someone please help me fast!
Old Jul 21, 2005 | 06:02 PM
03_Track_Z's Avatar
03_Track_Z
Default someone please help me fast!
Hi I'm sitting here with my dash totally apart and I don't know what wire goes to what speaker from the factory radio. I'm trying to hook up a line out converter but I don't know which factory wire to run to which converter port. Someone please help me!
Old Jul 21, 2005 | 06:07 PM
JCat's Avatar
JCat
Do you have the Bose or Base head unit?
Old Jul 21, 2005 | 06:10 PM
03_Track_Z's Avatar
03_Track_Z
base
Kevin3's Avatar
Kevin3
I checked nissan manuals out but the colors didnt match like they said they would. I would use trial and error! Dont install the speakers yet...just plug two wires to each one until you find the right one. There will normally be a blue and blue/black, purple and purple/black..and so on. Those will be each positive and negative.
Old Jul 21, 2005 | 06:26 PM
03_Track_Z's Avatar
03_Track_Z
well from my understanding i need to cut the factory wires coming out of the head unit and put them into the LOC, so if anyone could tell me what color from the HU goes to what speaker, that would be really helpful instead of having to cut each one individually. Thanks.
Old Jul 21, 2005 | 06:31 PM
Kevin3's Avatar
Kevin3
I remember the yellow aftermarket goes with Nissan yellow. The black wire will be the ground. The other ones I cant remember off the top of my head. I would trim all of the wires back until you have metal. Then just touch each aftermarket pair to Nissans pair. Its not as bad as it sounds. Only took me a few minutes. Plus, you can test your speakers to make sure they work ok before installing them.
Old Jul 21, 2005 | 06:46 PM
JCat's Avatar
JCat
Here is the page from the SHOP manual:
Old Jul 21, 2005 | 06:56 PM
03_Track_Z's Avatar
03_Track_Z
Okay I'm having trouble reading that diagram. Can anyone interpret for me? man im so lost...
Old Jul 21, 2005 | 07:03 PM
JCat's Avatar
JCat
At the bottom of the page are pictures of the three plugs. I believe you need to wire one speaker to pins 13 & 14 and the other speaker to pins 15 & 16.
I have the Bose System which is similiar, and don't feel bad, it took me a while to figure it out too.
Old Jul 21, 2005 | 08:27 PM
03_Track_Z's Avatar
03_Track_Z
Okay so 13 14 15 and 16 are the rear speakers, now there should be 4 more for the front speakers, 2 for each. Anyone know which ones they are?
Old Jul 21, 2005 | 08:34 PM
clkwrkorg36's Avatar
clkwrkorg36
use an ohm meter, to check for loads, then you know you have the speaker. then pop it with a 9v to see which one you have, or the easiest way is to buy a harness that is labeled plug it in find your wires and take it back.
Old Jul 21, 2005 | 10:26 PM
03_Track_Z's Avatar
03_Track_Z
http://liljerk.morpheus.net/350Z/dash_removal/
If you scroll down to step 15, you can see all the individual wires. Which 8 are the speaker wires? Thanks.
Old Jul 22, 2005 | 04:29 AM
JCat's Avatar
JCat
Plug has ten wires. Pins 1 & 2................3 & 4
seagrasser
Oct 11, 2015 03:27 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
