Stealth Installation of Valentine 1
Old Jan 27, 2004 | 06:50 AM
  #41
Z33Concept's Avatar
Z33Concept
Doesn't the V1 likes shows arrows like if Ur traveling east and a cop is heading west (Vice Versa) does it shows like a little arrow??
Old Jan 27, 2004 | 07:21 AM
  #42
little_rod's Avatar
little_rod
Hmm, just received my kit today, doesn't seem like the lines are long enough to reach from the back of the car (where the main V1 is) to the front where the fuses and remote unit are. Is it just my kit, or do I need to order/buy some longer lines before I do this install??
Old Jan 27, 2004 | 03:31 PM
  #43
zPilott's Avatar
zPilott
you can use standard telephone wires that you buy anywhere
Old Jan 27, 2004 | 07:50 PM
  #44
little_rod's Avatar
little_rod
Thanks.
Old Jan 28, 2004 | 07:30 PM
  #45
little_rod's Avatar
little_rod
Well, mine is done. Some changes to theirs, when I took the clip off for the visor mount that I used to mount the main unit, I used that clip to mount my remote under the dash. Not the sturdiest thing you will see, but it does work for me, and I didn't have to use any additional parts. Use mirror double sided tape to mount the remote right where jelledge mounted his remote unit.
Still trying to make sure that the main unit hasn't decreased in effectiveness. At first, I wasn't so sure, now it seems to be doing fine. Mounted it in the middle plastic screw, on the passenger side.
Old Jan 29, 2004 | 01:53 PM
  #46
Street Visionz, Inc.'s Avatar
I seem to have one slight problem with installation. I've seen the pictures of people hardwiring the v1 to the fusebox. How is this done? I tried doing this today with the red wire that v1 supplies and I can't seem to get the damn thing working. I tried hooking the power up to the cig lighter's fuse... and the v1 wouldn't turn on when the car started? Any idea as to what is going wrong?
Old Jan 29, 2004 | 05:15 PM
  #47
little_rod's Avatar
little_rod
Well, I had to cut off that end plastic thing. Then I stripped the plastic off a small portion, so that I could get some of the wire showing. Then I put the wire beside and around the metal part on the fuse. That should work.
Old Jan 29, 2004 | 09:33 PM
  #48
hey thanks man that did the trick!! lol okay so I've installed my friend's v1 now i need to go buy one. haha.
Old Sep 10, 2004 | 05:13 AM
  #49
ingenue007's Avatar
ingenue007
For those with problems with the plastic screw not retaining into the headliner, I would think another option is to go to the hardware store and find anchor mount screws (the ones that have prongs that flare out when you screw them in). Get ones with prongs wide enough, drill a hole through the V1 visor mount, put the screw through with washers and perhaps some foam around washers or foam on the visor unit to prevent unwanted noise, put the screw into the hole and tighthen screw. Prongs should flare open and hold the mount tightly onto the headliner. Then mount your V1 onto visor mount.
Old Sep 10, 2004 | 08:15 AM
  #50
dgtlbullet's Avatar
dgtlbullet
I have the same set up and it works GREATT. Especially for those who live in VA.
Old Sep 10, 2004 | 09:57 AM
  #51
asatyss's Avatar
asatyss
You can also get replacement headliner plugs at Lowe's that are a little bigger and will not pull out as easily. That's what I did and it worked great, no problems since.
Old Sep 11, 2004 | 11:12 AM
  #52
little_rod's Avatar
little_rod
Yeah, mine comes out partially and drops down all the time, too bad I have superglued the screw to my visor mount or I would take you guys advice and use a different screw. Oh well, that's life, could try some super glue remover I guess.
One thing I have noticed with this setup though is it seems to give better reception from the detector from the back than from the front. Maybe I am imagining it, or just love to worry about something, but the location might be taking away from the range in the front. With your V1 in this location, has anyone else noticed this??
Old Sep 13, 2004 | 12:41 PM
  #53
zPilott's Avatar
zPilott
I order a few of the headliner plugs from the dealer when I made an order a while ago. They are pretty cheap. The main problem with the plugs is they aren't made to be removed a lot. if you just leave it clipped in, with a new clip, it should be fine.
Old Sep 13, 2004 | 01:17 PM
  #54
LeMansZCa's Avatar
LeMansZCa
little_rod,
I think i have noticed that the front reception is not as good as the back...
looks like the rear view mirror might get in the way or passenger 's head
but i am still picking up signal from the front... just can't really tell if it's really weaker...
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
