Which amp for 10w7
Old Aug 4, 2005 | 12:50 PM
03znj's Avatar
03znj
Know it all
Default Which amp for 10w7
Which amp should i run with my w7 besides a jl amp
Old Aug 4, 2005 | 03:35 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Amps is amps.
Watts is watts.
Old Aug 4, 2005 | 05:12 PM
hksjza70's Avatar
hksjza70
Jl 500/1
Old Aug 4, 2005 | 05:13 PM
zand02max's Avatar
zand02max
Originally Posted by Paul350Z
Amps is amps.
Watts is watts.
Not true!
Why not go with JL either 500/1 or 1000/1!
Old Aug 4, 2005 | 05:43 PM
hndumafia's Avatar
hndumafia
1000/1 is a bit much for a 10w7 - the 500/1 is a great match (it's what i'm using).
Old Aug 4, 2005 | 06:13 PM
khsonic03's Avatar
khsonic03
500/1 is a great match, but basically anything with 500 watts RMS. If you look at the 10w7 power rating chart, you will see that 500 is what is recommended.
Old Aug 4, 2005 | 08:33 PM
03znj's Avatar
03znj
Know it all
I cant get a 500/1 for 300 but was looking to see if i can get a diffrent brand amp cheaper , whats retail on the 300/1?
Old Aug 4, 2005 | 09:29 PM
hndumafia's Avatar
hndumafia
you can't get a 300/2 for $300 either, unless you buy used - in which case you might as well look for a used 500/1.
Old Aug 5, 2005 | 07:04 AM
lil ze's Avatar
lil ze
If you go outside of a jl amp, make sure it is 1.5ohm stable.
Old Aug 5, 2005 | 11:48 AM
jdohman's Avatar
jdohman
why would you have to make sure the amp is 1.5 ohms stable? the 10w7 if a single coil 3 ohm woofer.. which means a mono amp would be running at 3 ohms mono. When looking at this config you need to look at both the 2 ohm rating and the 4o hm rating of the amp and find the middle. That is what the amp is going to do at 3 ohms.
Old Aug 5, 2005 | 03:01 PM
lil ze's Avatar
lil ze
So if he was running a mono amp at 3 ohms wouldit be making less power? then at 2ohms?
Old Aug 5, 2005 | 03:55 PM
jdohman's Avatar
jdohman
correct depending ont he damping factor. Most amps double power when you half the impedence. Jl amps on the other hand do the same power at every impedence with there favorite load being 4 ohm mono.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
