GPS Antenna location ?
Old Aug 20, 2005 | 02:39 PM
lungta's Avatar
lungta
Default GPS Antenna location ?
I just purchased a pioneer nav unit and i was wondering where you guys put your gps antennas ? I know some of you guys put in the center of dash between the vents by the windshield. How about putting it under the third brake light ? or in the trunk under the strut bar or inside if possible ???
Thanks
Old Aug 20, 2005 | 06:06 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I put mine on the dash between the defrost vents. I wanted it inside and that looked to be the best view of the sky.
Old Aug 21, 2005 | 04:35 AM
350zroadster's Avatar
350zroadster
I put mine Avic N1 on the passenger side of dashboard. It looks OEM.
Old Aug 21, 2005 | 02:27 PM
lungta's Avatar
lungta
Will it still work through plastic ? like under the dash or in the strut bar ? or under the brake light ?
Old Jun 20, 2006 | 07:09 AM
MOOCH10's Avatar
MOOCH10
Where is the location of the antenna installed by the dealer?
Old Jun 20, 2006 | 07:20 AM
JokerDev's Avatar
JokerDev
I have mine under the plastic cover on the rear strut bar. It's easy to pop off, can't be seen, and is directly under the glass so you get a good signal. It sticks on the metal since it's magnetic--don't even need to use the magnetic pad it came with
Old Jun 20, 2006 | 11:26 PM
gt3's Avatar
gt3
The OEM location is located in front of the instrument pod underneath the dash...let me see if I can find a pic of the location.
Old Jun 21, 2006 | 12:35 AM
gt3's Avatar
gt3
Here is a pic:
Old Jun 21, 2006 | 06:31 AM
james840a's Avatar
james840a
I also have mine under the plastic cover on the rear strut bar. I have my Nav unit gps ant. on one side and my sirus sat ant. on the other.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
