sub and amp question
hello everyone: i just traded in my gto for an 03track (daytona blue)
last night and i guess the previous owner had an alpine amp and sub (swe 1042) that was wired up wrong.....in any event, the dealership took them out and gave them to me.....would this be a suitable sub to go into the stock location? or should i have a custom box built for it....right now, there is no sub where the stocker should be.
thanks, any comments would be greatly appreciated.
last night and i guess the previous owner had an alpine amp and sub (swe 1042) that was wired up wrong.....in any event, the dealership took them out and gave them to me.....would this be a suitable sub to go into the stock location? or should i have a custom box built for it....right now, there is no sub where the stocker should be.thanks, any comments would be greatly appreciated.
you track model didn't come with sub. All Zs come with sub mount metal place but only Touring models come with sub (which is pretty much useless anyway).
If you want to save some space and have pretty decent sound, check out this (aka corner box):
https://my350z.com/forum/audio-builds/118365-finally-got-my-corner-sub-box.html
I have one of those and very happy with it. Since it has about .5 cu.ft., don't recommend it for any seroius powerpul subs but your type-s will work just fine with this box.
thanks for all the feedback....i ended up having best buy install it in the compartment but it doesn't sound too good...alot of vibrations as well.....looks like im gonna have to get a box....that corner box looked good....maybe i'll just get that.
thanks again everyone
yes they did use some dynamat.....but there are tons of leaks in the back area and the side....they only used dynamat in the front......its all good though, im gonna buy a box and just set it in the back....hopefully that will sound much better.
i think im just gonna order one from crutchfield.....the Q logic type II....nothing fancy.....but i first have to measure the dimensions to make sure it clears the rear window....i want something thats somewhat portable....so i can just remove it when i need to utilize the space.
