iPOD + VIDEO
Old Nov 13, 2005 | 11:15 AM
itburns's Avatar
itburns
Default iPOD + VIDEO
Has anyone heard of/tried hooking up a new iPOD (w/video) to a Nav Screen to play the iPod video? This would be a neat trick. I wish Apple would patna up with a stereo manufacturer to make a truly seamless connection, or install iTunes onto a head unit! Like they did with the Motorola ROKR w/iTunes. Is Apple listening???? They're missing a huge opportunity here.
Old Nov 13, 2005 | 12:44 PM
milkit's Avatar
milkit
theres no video output on the ipod, so i dont believe that would be possible
Old Nov 13, 2005 | 12:52 PM
PaK's Avatar
PaK
i have an ipod video, there is a video output but the problem that I have is only videos are displayed on the screen not the ipod menus
Old Nov 13, 2005 | 07:42 PM
isugoo's Avatar
isugoo
I have iPod video and I play video on my Eclipse AVN5435 without any problem. (not sure with stock nav.)
iPod's headphone jack has included video out along with stereo out.
Just connect iPod AV cable (http://store.apple.com/1-800-MY-APPL...plm=M9765G%2FA) to your ipod's headphone out.
And apple cable's RCA out to your video input on the headunit.
If you look at the apple AV cable carefully, its connection is slightly longer than regular headphone because it has video out.
Also in order to make ipod video play on the scree (or tv at homoe), you need to change its options.
to change option in the ipod, go to "videos>video settings>TV Out. and change it to on or ask (1. If you choose "ask": when you play video it will ask you "TV on or TV off" so if you want to see it on the ipod, select "TV off" or if you want to see it from external screen, select "TV on" then video will paly on the external monitor. 2. If you choose "on", your ipod video screen will just show title and video will only play on the external monitor)
Hope this helps.
Old Nov 14, 2005 | 08:13 PM
itburns's Avatar
itburns
Hope this helps.
Sounds like a really sweet setup, isugoo! Can you share pics?
Old Nov 14, 2005 | 08:33 PM
Inovashn's Avatar
Inovashn
if you want to save some money. the mini jack to video/audio out cable by apple is switched up. the generic plug that has mini jack to video/audio, all you have to do is switch the red and yellow rca's
Old Nov 15, 2005 | 05:22 AM
isugoo's Avatar
isugoo
Ok. I have take a few shots shortly.
jlb
Oct 15, 2017 05:10 AM
Justin100
Nov 29, 2015 03:58 PM
seagrasser
Oct 11, 2015 03:27 PM
Mw870
Oct 2, 2015 08:23 AM
