how do i take off that big black foam thing in the hatch?
Old Nov 21, 2005 | 02:02 PM
sharingan625's Avatar
sharingan625
Default how do i take off that big black foam thing in the hatch?
you know what im talking about. that big black foam thing that holds the jacking tools. how do i take those off? i've noticed there is one plastic pin holding the thing, but even after i remove the pin, the foam won't come out. i could've pulled it real hard but i wanted to confirm with you guys before i do. it looks like i could break that thing easy.
how do i take that foam out? i need to take them both out so i can put some sound-deadning materials in there. thank you.
Old Nov 21, 2005 | 02:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
If you've got the plastic off, the retaining nut off I seem to recall that they just pull out. They're not glued in or anything.
Old Nov 21, 2005 | 04:20 PM
sharingan625
thank you for your response.
what part do you mean by "plastic"? is there any plastic panet involved? all i took out was that round little plastic clip. and the thing was still not moving.
Old Nov 21, 2005 | 05:02 PM
Badfish25's Avatar
Badfish25
There may bemore than one clip. But I do know that those peices are hard to just pull out as there are more protrusions for non-existant clips, but those protrusions make it really hard to pull it out, but it can be done. OR just take apart that entire side of the trunk and then you can just pull it up.
Old Nov 22, 2005 | 07:34 AM
VO...'s Avatar
VO...
Administrator
In order to get the foamy things out, you have to pull the actual side panels off first. There are some screws holding the foam in, that are not visible until you remove the side panels. If you try pulling the foam out, after just removing the plastic retaining caps, you'll rip the foam apart. This applies to both pieces of foam. The foam on the driver's side is even more difficult to remove. This is beacause the foam sits on top of the Bose amp, but then again you have the Base model, so you probably don't have the Bose amp. Anyhow, you still have to remove the side panel.
Old Nov 22, 2005 | 11:52 AM
sharingan625
ah. thank you very much guys.
good thing i asked you guys before i did something stupid.
thx again!!
Old Nov 23, 2005 | 05:15 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Ehh, mine came out just fine without removing any panels. Took off that one plastic screw thingy on the floor and just used some force to pull the block out. Didn't break it or anything. You just have to kinda push up while you're pulling out.
Old Nov 23, 2005 | 09:11 AM
sharingan625
wow. thats a good news. i was looking at those side panels and scratching my head. do they go back in just fine? thx.
Old Nov 23, 2005 | 09:59 AM
VO...'s Avatar
VO...
Administrator
If ur gonna sound deaden the trunk, you have to take them out anyway.
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
