03' bose aux input?
Old Dec 1, 2005 | 05:06 PM
ceraldi's Avatar
ceraldi
Default 03' bose aux input?
I have a fairly simple question and I tried searching for the answer but came up with nothing... if there a way I can have an aux input to the deck without using a FM modulator? I want RCA input.
if not is the 04' deck compatable with the connectors and dash so I can use the PAC ?
Thanks,
Aaron
Old Dec 1, 2005 | 05:26 PM
ceraldi's Avatar
ceraldi
further searching has turned up more info but not totaly clear.... https://my350z.com/forum/audio-and-video/110740-adding-satellite-to-bose-how-to.html
basicaly somone was saying that this: http://www.discountcarstereo.com/detail.aspx?ID=610 will do the trick, but will it work with the in dash 6cd in dash unit I have?
Thanks again,
Aaron
Old Dec 2, 2005 | 01:28 PM
VO...'s Avatar
VO...
Administrator
not too sure what you're asking. are you trying to convert speaker outputs to RCA's or are you trying to hookup something like a PS2?
Old Dec 3, 2005 | 12:31 PM
ceraldi's Avatar
ceraldi
im trying to hook up my ipod to the factory 6disk in dash bose... so line in
Old Dec 3, 2005 | 03:58 PM
MySunset350Z's Avatar
MySunset350Z
if you have a SAT. button on your steering wheel then you can use the PAC AAI-NIS interface.
if not, then an fm modulator + ground loop (if the modulator doesnt already have one) + a seperate power filter would be your best bet. if you do go that route, dont tap into the cig lighter to power up the fm modulator. too many circuits are connected to the cig lighter so you will get a lot of noise making the ground loop and power filter ineffective.
Old Dec 3, 2005 | 07:11 PM
hondagal's Avatar
hondagal
I have an '04 Touring and I do not have a SAT button on my steering wheel so I don't know why MySunset350Z would tell you that. The 04 Touring does not come with any radio buttons on the steering wheel. I do use the PAC AAI-NIS interface with my satellite radio and it works fine. Was an easy plug-n-play hookup too once you get to the back of the radio..
Old Dec 3, 2005 | 09:42 PM
MySunset350Z
my fault. i was trying to say your vehicle needs to be sat. ready. i do believe some z's have an SAT. button on their steering wheels or radio, unless i was told wrong.
Old Dec 5, 2005 | 12:26 PM
CopperZ's Avatar
CopperZ
you can make an aux input. Someone did it here. it was a write up. about 1 year ago. im sure you can find it. the guy turned the cosset button into they aux switch. good luck
Old Dec 7, 2005 | 08:14 AM
Cuore_alfa's Avatar
Cuore_alfa
Answer:
If your HU is the Bose CD6 unit whit the CD6-TAPE-FM/AM input you need the AUXNISSv2 Auxiliary Input adapter, to switch from the CD Changer to the Auxiliar (Ipos, DVDs, PS2, etc) you need to hit twice the CD6 boton. Hope this help.
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
