****installed new cd player and now...***
Old Dec 18, 2005 | 11:26 AM
04silverzcoupe's Avatar
04silverzcoupe
Default ****installed new cd player and now...***
my windows dont roll up when you close the door. anyone have any ideas or experience soemthing similar?
edit:everyting is hooked up the same way as my cd plyaer i just took out except i forgot to hook up my antena.
Old Dec 18, 2005 | 02:04 PM
need Z's Avatar
need Z
Have you checked your fuses (in cabin and under the hood) to make sure that none of them have blown?
Old Dec 18, 2005 | 05:37 PM
04silverzcoupe
not yet. after the install i prety much just stopped for the dya. ill contine tomorow and see what i can figure out.
Old Dec 19, 2005 | 12:01 PM
04silverzcoupe
fuses all good. anyone else have ideas. i realy need this fixed by tonight.
Old Dec 19, 2005 | 12:54 PM
TonyToca's Avatar
TonyToca
you checked both sets of fuses? under the hood and in the cabin like need Z said?
Old Dec 19, 2005 | 01:06 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Have a look at fuseable link 40A which is just forward of the battery under the hood. It's in the back, closest to the battery, and just to the centerline of middle in at that back row of junk. You'd have had to do something really bad to blow this thing (welding/big sparks)
The fuse is a 10A fuse number 1 located in the J/B fuse box which again is under the hood above to the body control module in the driver's side kick panel. It's more that likely you popped this guy (smaller sparks).
Old Dec 19, 2005 | 01:10 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Fogot to add. Try using the key in the outside door lock to see if you can get the windows to move. Put the steel key in the lock and twist to "lock" the door and hold it there for two seconds - the windows should roll up. Twisting the key to "unlock" the door and holding it against the spring for two seconds should cause the door to roll down.
This technique will by-pass the switches in the door if they were bad.
Old Dec 19, 2005 | 01:28 PM
VO...'s Avatar
VO...
Administrator
Good info.
Old Dec 19, 2005 | 04:29 PM
04silverzcoupe
yeah i pulled them all on the inside and pulled the ones i oculd under the hood and just eyeballed the big ones. they all looked fine.
Old Dec 19, 2005 | 04:36 PM
04silverzcoupe
went downstairs to try this and on the way i held down the unlock button on the key fob to auto roll down the windows while i was walking down the stairs. well i got in the car and rolled the windows back up adn they went all the way back up. i then opened and closed the door a couple of times and each time the windown lowered and raised as it should.
thakns for the replies everyone. knew i could count on ya'll.
bcoffee20
Nov 19, 2015 06:39 PM
jelledge
Nov 25, 2005 06:21 AM
wadd3456
Jan 19, 2003 06:43 PM
grutter
Dec 9, 2002 07:39 AM
