Head Unit Installation
Old Jan 30, 2006 | 01:29 PM
sundevil67's Avatar
sundevil67
Default Head Unit Installation
I had this head unit installed last week:
underneath the unit there is a space between the deck and the trim panel, and you can see into the dash. It is something probably no one else would notice besides me, but it kind of bugs me. I am wondering if anybody here knows of a way to fix this; if there is any kind of way to make it completely flush, or if I am just being too picky and should leave it alone. I know the bottom of this particular head unit is sort of oddly shaped, and that probably doesn't help. I tried to take some photos to show what I mean - they aren't that clear, but you should get the gist.
Old Jan 30, 2006 | 03:42 PM
SungNamZ's Avatar
SungNamZ
It is hard to tell from your pics, but it looks like you used the Metra dask kit from Crutchfield.
Old Jan 30, 2006 | 07:30 PM
sundevil67's Avatar
sundevil67
I am not quite sure which kit it is; but do you guys think it is possible to do something custom that will close the gap?
Old Jan 30, 2006 | 09:08 PM
Dr.Z's Avatar
Dr.Z
You might think about doing a mod like this one listed for installing tweeters:
http://www.*********.com/zwiki/Tutorial:Tweeter_Mod
It discusses how you can use pieces of the plastic as filler after you've dissolved them in model cement. If you've got leftover pieces from your dash kit, you could break them up and make the putty they're talking about and form that into your space. I would also recommend giving a very light coating of Vaseline or something on your H/U's bottom before you do this so it doesn't stick. After it's set, you could remove the H/U and sand the molded area until it's smooth. You might also consider removing the dash kit and painting it to look like your dash after it's done in case there are any color inconsistencies. Good luck.
Derek
BTW-replace the *** with the tech site addy
Old Jan 31, 2006 | 07:17 AM
sundevil67's Avatar
sundevil67
The tech site? What is that full URL? It sounds like that would work for me - but I would have to get a pro to do it right; I would never attempt that on my own. Thanks!
Old Jan 31, 2006 | 02:48 PM
z350boy's Avatar
z350boy
How about using rubber sealing strips. You can either slide one into the gap and stuff it in until it sits just right or remove the unit and glue the strips down and reinstall the HU. Just my 2c
May 30, 2017 03:28 PM
