Amp is wierding me out..
Ok I installed my amp
Everything is hooked up and plugged in. Turns on plays for 5 seconds then goes into protect.
I unhook the RCA's and it comes out of protect.
I think its bad ground find new ground, and try again..
Same issue.
Any ideas?
Same issue.
Any ideas?
Same issue.
Any ideas?
Same issue.
Any ideas?
That was one of the issues, THe speaker was dual 2ohm and I though it was dual 4ohm. Fixed that by putting the speakers in serial, then it started working. BUt after about 10 min it went out again.
Same problem.
Same problem.
Ten minutes is too short for the amp to thermal clip (especially now at 67oF in RCo). Since the fuse is holding it's not an external short. Are you running >2V preamps, some amps can't handle higher voltage and need a line converter. What brand/model is the amp?
>sounds like your putting a high voltage input into a low voltage input
Given the clues (assuming one speaker coil isn't shorted) I agree. It's time for a new amp! Lucky for you there are a couple of great amp options. Did you save your receipt?
I got a pioneer elite 860mp
and its a autotek SX-475
200 x 2 @ 4 ohms bridged.
However only one "side" is hooked up.
Im going to get a different one, I got it from my stereo shop buddy, It was a display amp and I got it for $100 so I cant complain too much. He is going to switch it out with something else..
m_0g
Jun 3, 2021 10:05 AM
wanderingstuden
Jan 28, 2016 07:03 PM
bcoffee20
Nov 19, 2015 06:39 PM
