Acrylic Sub enclosure?
on
The cuts would have to be absolutely perfect and sealed very well to prevent leaks. Any flex in the acrylic will result in a substantial loss of sound volume. While it's possible to make a box completely out of acrylic, I wouldn't recommend it.
leaks?? Wouldn't MDF leak more than acrylic. Wood compare to plastic. A good silicone seal would ensure a waterproof cube (like a fish tank).
I suggest it cause its way cheaper than mdf, and a good cover of dynamat would kill the vibration.
on
It's brittle and prone to cracking/splitting in a violent environment such as a sub.
I've hand built a few of my aquariums and they were all glass; no acrylics.
MDF is more rigid and more robust, it will stand up to abuse better than acrylics. By the time you get a comparable level of stiffness and durability out of an acrylic sheet, you're basicly looking at bullet-proof "glass"; which is indeed more expensive than MDF.
bcoffee20
11-19-2015 06:39 PM
