best place to ground a head unit?
Old Feb 13, 2006 | 11:13 AM
ghost11's Avatar
ghost11
Default best place to ground a head unit?
being that this is my first car, it is also my first stereo install. i bought an alpine head unit, and on the wiring harness there is a wire with a connector to atatch to a bolt. is there any certain bolt where i would get the best ground?
i tried to search but everything i found was about engine grounding, thanx
Old Feb 13, 2006 | 11:51 AM
HarvesterUT's Avatar
HarvesterUT
i bolted it to a small screw under the shift boot. there are 4 of them holding the rubber shift cover in place. just loosen one abit and slide the grounding prongs underneath and re-tighten. like a champ
Old Feb 13, 2006 | 12:54 PM
djParis's Avatar
djParis
Retired Racer
Why not just ground it to the wiring harness?
Old Feb 13, 2006 | 01:10 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There is a large dashboard grounding point for the harness just behind the combo-gauge in the triple gauge cluster. There's about ten wires in the bundle that hits a bare steel looking pipe that's running the width of the top forward part of the dash. Once you pull the center console out just look around up there and it will come to you.
Old Feb 13, 2006 | 07:40 PM
ghost11's Avatar
ghost11
is it ok to ground several things to the same place? will i get as good of a ground? will it work with the kind of connector i'm talking about (the kind that goes under a bolt?
_______________________________________
i doubt there was a 350z when you were 16
Old Feb 13, 2006 | 07:44 PM
ghost11's Avatar
ghost11
you mean ground the alpine wiring harness to the nissan adapter wiring harness? i think the adapter has a wire that it says to hook to the chasis of the headunit, shound i just attatch the alpine grounding wire to it?
Old Feb 13, 2006 | 07:45 PM
ghost11's Avatar
ghost11
thanx for the help by the way guys, i hope i'm not explaining this wrong
Old Feb 13, 2006 | 08:11 PM
djParis's Avatar
djParis
Retired Racer
Yes its perfectly fine to splice the alpine harness wire into the nissan adapter wiring harness. I have mine wired like that, and have had it like that on all of my previous cars. Its easy, and you know its grounded correctly that way.
Old Feb 14, 2006 | 06:15 AM
FirstZ's Avatar
FirstZ
I learned many installs ago the factory grounding wire is the best route!
Old Feb 14, 2006 | 06:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There were Z's when I was 16 ... I'm not THAT old. My dad did let me spend my money and to get a job to feed and insure my '73 Plymouth.
Yeah, the best thing to do is to ground everything together - that's the function of the ground - to gather up all the negative leads and deliver them back to the battery source. The screw has enough thread to slip another lug under it. The typical split "Y" looking terminal will work just fine.
Old Feb 14, 2006 | 10:42 AM
ghost11's Avatar
ghost11
i think this is what i'm gonna do
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
