Sub/Amp RMS watt help
Old Mar 12, 2006 | 05:02 PM
Kee1337per's Avatar
Kee1337per
Default Sub/Amp RMS watt help
Hey guys, i've started looking into putting 2 infinty perfect 10" subs into the back of my 350z, and have been wondering how powerful of an amp I would need to power them to their fullest ability. I know that I could get a sub with either a dual or a single coil on it with 4 ohms to each coil, and that the optimal RMS for each sub is 350watts... so how many watts of RMS should i get in an amp to power these subs?
Old Mar 13, 2006 | 12:09 AM
JimRHIT's Avatar
JimRHIT
Get an amp that will put out a solid 600W RMS at 2 ohms and you'll smile all day long. Don't worry about the biggest number of watts you get buy, just get a nice quality amp to pair with them and they will sound excellent.
This is considering you get a pair of single 4 ohm Perfects.
Good Luck
Old Mar 17, 2006 | 11:32 AM
Kee1337per's Avatar
Kee1337per
does the amp need to be bridgeable for this to work?
Old Mar 17, 2006 | 12:21 PM
pingrr's Avatar
pingrr
I have a Phoenix Gold 200.4 and it pushes the speakers very nicely. I got my amp of ebay for about $250.
I have the same speakers you are talking about Infinity perfect 10.1's
Old Mar 17, 2006 | 12:32 PM
JimRHIT's Avatar
JimRHIT
No, the amp doesn't have to be bridgeable ... but if the subs are in a shared airspace box, I would definitely recommend a bridged amp.
check ebay for a jbl bp600.1 ... that will do an awesome job for you.
Old Mar 17, 2006 | 12:39 PM
jcarp's Avatar
jcarp
i'd go for a memphis 1000 and you will love it. do with the dual voice coil set up and it will slam.
Old Mar 17, 2006 | 01:00 PM
Old School's Avatar
Old School
Shift_Boost
+1 I have a Memphis 1000D and it slammed the **** out of my JL 12W6s....now I have it powering some ID8s. Man that amp rocks!!~!!
Old Mar 17, 2006 | 01:01 PM
JimRHIT's Avatar
JimRHIT
that memphis will work just as well. 1000W is gonna be a lot of power for those if you really crank it up.
Old Mar 19, 2006 | 11:55 AM
Kee1337per's Avatar
Kee1337per
I was looking at that amp.... powerful man, but I like it. Why at that point would I need to get the dual voice coils?
Old Mar 19, 2006 | 08:57 PM
Kee1337per's Avatar
Kee1337per
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF1211A'&Ser=REF&Cat=AMP
would this amp be fine for those 2 subs? if so, what type of sub would i need.... single or dual coiled?
Old Mar 19, 2006 | 10:22 PM
JimRHIT's Avatar
JimRHIT
You would need the DVC in oder to get down to 1 ohm to get the most power out of that amp.
Old Mar 19, 2006 | 11:25 PM
Kee1337per's Avatar
Kee1337per
gotcha.... so if i wanted to run the 2 subs at 2 ohms, would I want to get the single coil, or dual?
Old Mar 20, 2006 | 07:37 AM
JimRHIT's Avatar
JimRHIT
depends on the voice coils. when you parallel a pair of subs, the impedance will be half.
so if you get two single VC subs (4ohms each) .. you' parallel them for your 2 ohm load
raceboy
Audio Builds
29
May 31, 2003 01:33 PM
jl215
May 23, 2003 05:56 AM
JZC
Jan 3, 2003 06:02 PM
eliminate
Dec 26, 2002 08:02 PM
