Dynamat Effectiveness?
Old Feb 3, 2003 | 04:14 PM
The Sopranos 16's Avatar
The Sopranos 16
Question HELP My Trunk Rattles, Does Dynamat Work?
I recently put a JL 10W7 in a custom box in my trunk. The W7 is a great speaker and the sound quality is unbelievable, however, I am listening to as much of my trunk as I am the woofer. The car just vibrates way too much. The only think I can think of is to Dynamat the trunk area to try and reduce the rattling. I've never used Dynamat before so I was hoping that someone who has can tell me about it. Should I be expecting a just slight reduction is the rattling or will this stuff make my car completely quiet and tight? Any other suggestions on how to help solve this problem would be great
Old Feb 3, 2003 | 10:53 PM
2k3silver350z's Avatar
2k3silver350z
if you are doing large areas i would recomend brown bread. i would also recomend spraying it first with a few coats of dyna shield or any other form of spray dampner. this will also cut back on road noise.
Old Feb 4, 2003 | 10:11 AM
onecoolee's Avatar
onecoolee
Default Ever heard of FATMAT ?
I used about 50 sqft of a new material called FATMAT in my install. I did my doors, trunk/hatch, wheel wells, and anything else I thought might vibrate. FATMAT is easy to apply and performs similar to Dynamat Extreme, except the cost is about half as much. It is supposedly advertised as a direct replacement for Dynamat extreme and has the aluminum backing and super sticky adhesive side. I think I paid $125 shipped for 100 sqft which included a solvent to make sure the application area was clean, a utility knife, and roller tool. So far, I am very happy...my car is much quieter, and the wheel wells much more tolerable (less stone noise). I have yet to install my 10w6 in the hatch, but I think all the time I spent putting this material down will pay off...
If you want a good laugh, check out the factory dampening material on the rear wheel wells...what a joke ! Mine wasn't even stuck down, I pulled both sides off with a little pressure. Needless to say, I redid all of the factory areas with the FATMAT...
lapham3
Oct 7, 2022 03:15 PM
Vigman
Nov 17, 2015 04:34 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Paul.
Oct 16, 2015 07:34 PM
PureR3d
Sep 10, 2015 06:23 PM
