Just removed garbage factory system
Old May 14, 2006 | 03:01 PM
sidewayz2's Avatar
sidewayz2
Default Just removed garbage factory system
I just finished a system swap from factory components to aftermarket. Man what a difference. The factory separates in the front doors are a friggin joke. Why on earth would Nissan put such garbage in a car like this. Well anyway I put Infinity 6.5 components in the doors using the factory speakers as spacers and factory tweeter mounts as well. Infinity 6.5 coaxials in the rear, Memphis 4 channel and Memphis mono block on an Alpine 10 inch type r sub. I left the factory radio for now because no proper kit is available. All in all it sound awesome I was very surprised at the clarity I got from the fact. radio. I did have to mount a bass **** in the compartment above the radio to control the woofer. The car was surprisingly easy to take apart and put back together. I thank all who posted instructions for disassembly of the Z.
Old May 14, 2006 | 06:47 PM
bdblackz's Avatar
bdblackz
cool... would you able to post pics of how you used the stock speakers as spacers? i am thinking about getting the same speakers, but not quite sure what ya mean.. thanks man
Old May 14, 2006 | 09:50 PM
sidewayz2's Avatar
sidewayz2
I cut the cone assembly out of the plastic speaker housing. Using a pair of dikes you cut the plastic ribs on the speaker, this leaves a perfect hole the same diameter as the new speaker. As long as the new speakers are not to deep it works great. The factory tweet location will fit the infinity tweets perfectly using the factory mounts . There is enough room for the crossover in the lower rear of the door to mount.
Old May 15, 2006 | 04:43 AM
03zsmith25's Avatar
03zsmith25
can you post some pics of the tweet install? how did you get the covers off? i jsut replaced my doors w/infinity coaxials and the tweeter cover didnt come off. i have some fultron tweeters id like to put in there
Old May 15, 2006 | 10:27 AM
Swiffer's Avatar
Swiffer
What did you use to tap your amp/sub into? I saw that you were using the factory HU, and I was curious if you used a LOC or not.
Old May 15, 2006 | 05:05 PM
sidewayz2's Avatar
sidewayz2
Talking
Mounted tweets behind factory grills and yes it's very bright and clear. As for the factory mounts the tweeters for the infinity reference 6.5 components are very tiny and fit just like the fact. ones. I used 2 loc's frt. and rear and they fit perfect under the ac controller box which needs to come loose when you take the huge radio bezel out. If you position them right if you need to adjust them just unsnap the shifter bezel and the adj. screws are right there. I took my time and carefully removed all panels from car then ran wires and started install. You will notice the amps are not perfect in the amp rack ....but it was 95 degrees and there comes a time when you say ...what the @#%** just get it done. I will redo when the Z enclosure arrives but for now 1000 percent better sound. Anyone needs an opinion of the new Memphis amps well I have one ......super clean and very small. Overall this system is so much louder than I really need( I'm 35 years old) but whats a Z without boom ? Anymore questions..now is the time while it's fresh cause it fades fast on an old stoner.
Attached Thumbnails Just removed garbage factory system-dscn00130001_1.jpg   Just removed garbage factory system-dscn00100001.jpg
Old Jul 12, 2006 | 09:04 AM
Blue_Z's Avatar
Blue_Z
I have some BA components that I'd like to install into my doors but am afraid to take apart the car cuz I might f*#k something up. All the instructions I've seen so far to take apart the door panels are for 03-05. What did you do to get the driver's side off?
For the tweeter, did you just remove the plastic panel for that area and replace it there? I'm glad to hear this cuz I was afraid I'd have to cut some big holes there. Would you recommend this install for a novice?
Old Jul 12, 2006 | 09:47 AM
Voboy's Avatar
Voboy
Drivers side door is easy in the 06. Pop off the plastic panel with the controls, take out one screw, and the other is at the door handle. After that the whole panel is ready to come off. You must remove the door panels, and then the tweeter panel can come off with ease.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
