Sub box for spare tire well?
Old May 25, 2006 | 07:21 PM
o snap its eric's Avatar
o snap its eric
will be done on sat.
Old May 26, 2006 | 10:59 AM
esfand's Avatar
esfand
ok i did this and finished a couple of weeks ago.... first of all it sounds like ****.... i either have to make another one or try and fix this one. i used 3/4 inch MDF for the top baffle, and it just vibrates like all hell. if you put ur hand on it when the sub is hitting ur hand will look blury. i used the entire area and fiberglassed the bottom portion.....
Old May 26, 2006 | 11:11 AM
bjr's Avatar
bjr
got any pics??
Without them I am going to assume the fiberglass is not thick enough?
You should be able to push on the fiberglass box with your hand pretty hard and it should not flex. If you do the layers nice and tight with no air bubbles you may get by with 1/4" thick but most go thicker.
Give some more details or a pic. It should be an awesome spot for your sub if you get it right!
Old May 26, 2006 | 12:03 PM
JimRHIT's Avatar
JimRHIT
How many layers of glass did you do?
You should be able to jump up and down on your box (without it breaking) before you install it .. we call this the elephant test
Old May 26, 2006 | 12:27 PM
VO...'s Avatar
VO...
Administrator
did you dynomat the trunk?
Old May 26, 2006 | 12:31 PM
MRMDFY's Avatar
MRMDFY
Bracing is going to be critical in an enclosure like this. You can't expect to just slap a huge piece of 3/4" MDF on top of a fiberglass frame and secure only the perimeter. You need to construct adequate bracing within the enclosure. Cut MDF braces and sandwich them between the MDF baffle and the bottom and sides of the enclosure. Use glue and screws at the top, then fiberglass the braces to the top and bottom. This will eliminate flexing and vibration.
Old May 26, 2006 | 03:12 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
the stealth install i just did is up...
the enclsoure is solid mdf, with a shallow enough sub, i got to rasie the floor by only an inch and a quater, even wtih foam dampening under the box
b
Old May 26, 2006 | 03:14 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
on your site?
