aftermarket dvd help
Old Jun 3, 2006 | 05:39 PM
ritzthekracker's Avatar
ritzthekracker
Default aftermarket dvd help
ok so i recently bought a 2006 350z touring coupe with the stock navigation and what i am lookin to do is put in a aftermarket dvd/cd player such as the pioneer AVH-P6800DVD in place of the stock cd player. my question is if i was to do this would my navigation function properly? i am not commited to getting that receiver either so if you guys have any suggestions on good reciever that would also would be great.
Old Jun 4, 2006 | 11:59 AM
ritzthekracker
anyone?
Old Jun 4, 2006 | 12:45 PM
Derek's Avatar
Derek
Theoretically, you should be able to use the Navi if you ditch the factory HU. There are four wires that go from the Navi unit to the Bose (clarion) HU. They are located in the 16-pin connector.
On the back of the Bose, the wire colors are:
R/B (pin 24) : Navi ON signal
W/B (pin 30) : Navi Input -
B/P (pin 31) : Navi Ground
L/B (pin 32) : Navi Input +
The Navi On signal is +V when activated. I can't tell what the condition is - the shop manual says its hot when "Voice" button is pressed. This is probably the mute/interrupt for the audio unit. The +/- pins are the audio signal for the Navi voice itself.
Depending on your HU, you should be able to wire this into your aftermarket system. Might want to search the forum to see if anyone else has already done it. Looks fairly straightforward to me.
Its interesting to note that if you don't have factory Navi, you could probably use these inputs to wire in a mute/interrupt into your bluetooth handsfree unit or even have the audio from the handsfree unit route into the factory HU. Interesting.
Old Jun 4, 2006 | 03:10 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I am sure there is an adaptor somewhere
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
