remote amp wire
Old Jun 15, 2006 | 12:37 PM
350ztoronto's Avatar
350ztoronto
Default remote amp wire
so i searched and didn't find much
i heard that the remote turn on amp wire could also be wired to the power anntena can someone confirm this cause i have 2 amps and one will be wired to the regular remote wire and the other to the power anntena
Old Jun 15, 2006 | 12:39 PM
josh846's Avatar
josh846
well i would think wired to power antenna it will only come on when you have it on FM or AM not a cd, but i am not an expert. I am guessing you have the factory deck?
Old Jun 15, 2006 | 12:41 PM
350ztoronto
nope everything is aftermarket -_-
or could i just split the remote wire? would that be easier?
Old Jun 15, 2006 | 02:43 PM
350ztoronto
bump bump bump
Old Jun 15, 2006 | 04:36 PM
justinrlamb00's Avatar
justinrlamb00
I've always ran all of my amps off of the remote wire...if you are uncomfortable doing that you can run them off of any "ignition" wires.
Old Jun 15, 2006 | 04:38 PM
stereoneeds's Avatar
stereoneeds
yes, you can either splice your remote wire and run it to each amp, or run it to one amp, and then run a "jumper" wire from that amps remote terminal to the other amps remote terminal.
Old Jun 15, 2006 | 06:06 PM
Swiffer's Avatar
Swiffer
Just tap into the wire for the cig lighter. Split it and run both amps off of that.
Old Jun 15, 2006 | 06:43 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Since everything is aftermarket... Daisy chain the remote wires between the amps.
You dont need a seperate remoted wire for every amp coming from the Deck. It is just a 12v source that flips a switch in the amp and tells it to get off its *** and play some music
Old Jun 17, 2006 | 11:22 PM
350ztoronto
cool got it working today thx boys
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
