Courtesy's 06 Motorized Nav Door install (56k warning)
Old Jul 12, 2006 | 10:22 AM
  #41
SmokyTyrz's Avatar
SmokyTyrz
Ok, I think Punish is talking about getting the upper-center console to seat correctly, and wiring being the cause (aside from access to the two bolts, like a couple of us have).
But the gap between the mating surfaces of the nav cubby and the console is due to the nav vs non-nav console differences.
Desi, et al: You need to contact a user on this forum named 'BPL'. He can build you a custom microprocessor which will control the nav door without the OEM nav "brain".
Do a search on my350z for BPL, nav door, etc. and you'll pull up plenty of info.
Cheers,
-Smoky
Old Jul 12, 2006 | 11:40 AM
  #42
DesiZ_06's Avatar
DesiZ_06
hey smoky..i found the infos!...thanx alot!..will look into and decide what to do depending on my budget...thanx!
Old Jul 12, 2006 | 01:30 PM
  #43
evobunny's Avatar
evobunny
Cheers,
-Smoky
So smoky did you buy the microprocessor from BPL yet. Detail please. how much, and if it works.
Old Jul 12, 2006 | 01:48 PM
  #44
SmokyTyrz's Avatar
SmokyTyrz
Yes, BPL built the one I am using and it works great. Door is smooth (as smooth as OEM anyway). Works every time! You can even configure the operation using a mechanical jumper on the processor board which allows you to choose between: "Remember pre-shutdown door status (open/close)" and "Door always shut on start-up"
It's very slick!
Old Jul 13, 2006 | 07:17 AM
  #45
turbohappy's Avatar
turbohappy
Hmmm. I did and didn't find what you are talking about. Anyone have the link?
Old Jul 13, 2006 | 10:36 AM
  #46
DesiZ_06's Avatar
DesiZ_06
https://my350z.com/forum/audio-builds/94798-my-z-pc-install-2.html
there
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
