JBL VS. Directed Amp
Old Aug 28, 2006 | 06:23 PM
psunner's Avatar
psunner
Default JBL VS. Directed Amp
hey guys...I need to get a 5 ch amp, i was looking at JBL 755.6 II or the Directed D2205. I don't know much about all the power ratings and need help choosing which one i should get. i have 1 15" Image Dynamics sub and kenwood dpx-701 HU. Any help would be great. thanks.
Old Aug 31, 2006 | 08:34 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
JBL: 560 Watt 6-Channel Power Amplifier
• The GTO755.6 II's high output MOSFET power supply ensures optimum power delivery into numerous impedances with low distortion.
• The 755.6 II comes outfitted with three variable 12dB per octave electronic crossovers allowing you to optimize system tuning based on speaker location and accompanying loudspeaker components.
60 watts RMS x 4 channels + 107 watts RMS x 2 channels
at 4 ohms and ≤ 1% THD + Noise
160 watts x 2 + 300 watts x 1 at 4 ohms, 14.4V supply and ≤ 1% THD + N2
Directed D2205 5 Channel Stereo Amplifier: 2200 watts
*High speed MOSFET switching power supplies
*Built-in high performance, variable12dB/octave 2 way active crossovers
*Switchable 8 dB bass EQ function
CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 80W x 4, CH 1-4
CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 280W x 1, SUB
(Good luck with getting 14.4 volts out of your battery! )
The Directed amplifier might be a nat's *** louder with it's "extra" 20 watts per channel in the front and 20 watts less in the subwoofer as you're much more likely to notice the extra 1 dB in the front (possibly on a good day and if you have formally trained ears and listening to a constant tone source).
Coin toss really. At least JBL was a close in their power ratings but I like the Directed as I think it's more pretty looking.
Old Aug 31, 2006 | 08:38 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
based on past and some present experince with both cmpnaies, like paul said, its a toss up, honestly, you arent going to notice the extra 20 rated watts with your ears.
i personally would go with whcih ever one looks better and/or is cheaper to you
but an id 15, not sure which one you have, would bgenefit from about 200 more watts than either of those can dish out but it will still sound fine
b
Old Aug 31, 2006 | 02:36 PM
StreetOC192's Avatar
StreetOC192
I had the Crossfire VR705d in my system in my Xterra running Boston Acoustics SL60's bi-amped with the 4 front channels and a Boston Acoustics G51044 subwoofer. This amp is a powerhouse in the 5-ch amp arena, puts out more than rated power at 14.4v. Stays cool too. You can find it for $450-ish.
http://www.crossfirecaraudio.com
Old Sep 1, 2006 | 12:48 PM
psunner's Avatar
psunner
thanx guys, i ended up getting the directed one after talking with few local shops and got a really good deal on it. Just have to install it now to find out how it sounds. I had a JBL b4 this it fried, so i think directed would be a better choice and it looks a lot cleaner. thanks for the input
Old Sep 1, 2006 | 12:52 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
how a system sounds in the end in myhonest opinion:
90 percent installation technique
5 percent how good the front speakres are
3 percent how the interior of the car is like
2 percent rest of the equipment lol
not accounting of course for junk equipment of course
so basicalyl, get a good install!
Old Sep 1, 2006 | 01:35 PM
psunner's Avatar
psunner
other than hooking all the wires correctly, and considering good quality wires, what else depends on the installation
Old Sep 1, 2006 | 02:03 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
thigns like dampening the right places
door mounting versus kick mounting
correct guage wires
rca run away from power cable
perfectly sealed box of the right size
tuning..
etc etc...
basically my point is given the same equipment and the same car, you can get vastly different results depending on how well and where the things are installed
b
m_0g
Jun 3, 2021 10:05 AM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
_koubie_
Sep 20, 2015 06:34 PM
