AUDIOHEADS:What's the best sounding bass????
Old Sep 2, 2006 | 06:42 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
More important that the driver is the box that its mounted in. You don't have to go with a sealed box and in fact you can get sereral times more bass by going with a vented box or a transmission line. My personal choice for best sounding bass would be Klipsch KornerHorns backed into proper corners. I'd suffer with LaScala's if I had to.
Old Sep 2, 2006 | 06:59 AM
vantage350z's Avatar
vantage350z
what are Klipsch Korner Horns?
Old Sep 2, 2006 | 07:40 AM
dkmesa350z's Avatar
dkmesa350z
I had a RE XXX 12" powered by 1850 watts in the Z and people 2 blocks aways would turn around looking pissed. FYI play Late Night Tip by Three 6 Mafia to test your bass.
I don't think it will take a huge upgrade, unless you consider 2 better 10s and a huge amp a huge upgrade. I have 2 Alpine Type Rs with the same 1850 watt amp in .65 cubes each and it has broken 2 of my rearview mirrors.
Maybe you can accomplish what you're looking for by making a different box for your current setup. Try getting a experienced person to build you a good ported enclosure and if it doesn't satisfy you, you haven't spent nearly as much money as a whole new setup
Old Sep 2, 2006 | 09:51 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by vantage350z
what are Klipsch Corner Horns?
Klipschorns are $7500 a pair when you can find them. They use a folded woofer horn which uses the walls of the room for the final fold.
"Commonly called a corner-horn speaker, the remarkably uncommon Klipschorn includes a highly efficient horn loaded tweeter and midrange compression driver. Its patented folded-horn 15" woofer delivers powerful low frequencies.
Considered a watershed industry event, the introduction of the Klipschorn set the standard for high sensitivity, wide dynamic range, low distortion, and smooth frequency response. These principles, which drive the creation of every single Klipsch loudspeaker, are what make the Klipschorn as sought after today as it was decades ago.
As the only speaker in the world to be in continuous production for 60 years, the Klipschorn has remained relatively unchanged since its inception. In 2005, the company made some minor cosmetic and functional revisions to this legendary speaker, including the elimination of the inset collar, or spacer, between the upper and lower cabinets for a cleaner aesthetic appearance. A horizontal wall seal was added to improve the low frequency horn's response accuracy."
I heard some in downtown Tokyo and have wanted them ever since. The Belle's a bit cheaper at $5500 a pair and don't require mounting in a corner. Seeing as how they're over 50" tall and weigh-in at 175 pounds each they're not car worthy. If you ever have a chance to audition these do yourself a favor and see what Paul W. Klipsch invented prior to computers and plastic speakers.
Old Sep 2, 2006 | 08:54 PM
dTor's Avatar
dTor
I think a TL setup would be a bit on the large side for a mobile audio application... unless you're towing a trailer that is 6' or longer.
Old Nov 6, 2006 | 08:13 PM
hiz-n-herz's Avatar
hiz-n-herz
Originally Posted by dTor
Any specific brands anybody spouts off here (including me) is purely subjective and limited by the first hand experience any one person has had with the equipment they are recommending. For the most part, any good quality sub(s) with plenty of clean power in a well built and tuned box will give you the kind of bass you want. Just demo as many different combos as you can before making a decision.
Rattling is proportional to the total SPL of your system and how little you dynamat/foam/tighten the rattles that you find.
You will find that (typically) the more money you spend, the better of a system you will get.
+1 for all that...
I see people who put too big of a woofer into too small of a box and it sounds like crap.
Are you looking for that kick-drum impact? Or that 25-20 Hz Synthesized bass that just carries for blocks? Decide how much space you want to give up to a sub (and how much weight you are willing to add for the box) and get whatever size/combo subs best fit that space. I have always liked 2 12" subs. But I don't want to put 100lbs of subs and box in my Z so I'm undecided.
Here's an old system I had in a CRX... Friggin deep, low, accurate bass that'll almost take your breath away!
http://www.sounddomain.com/ride/107550/1
+1 for Crystal Method! Also some of the bass mekanix stuff was fun...
Old Nov 9, 2006 | 07:12 PM
AXIS6969's Avatar
AXIS6969
Originally Posted by DZTZ33
I'm looking for that purest, clearest, smoothest, and deepest bass. I want that bass where you can from hear it two blocks away. Where you can feel it in your stomach, even at low volume. I DON'T want that trunk rattling bass where it sounds like every screw in the car sounds like it's coming loose.
I know there are a ton of variables that contribute to bass quality: sub size, brand, number of subs, box size, ported, band pass, amp, wiring, etc.
Right now, I have a custom job in my trunk. The spare tire was taken out, and I have two 10 inch JL W0's powered by a Rockford Fosgate amp, and an Alpine amp powering my Boston Accoustic Components.
It sounds great, and the bass is powerful, but I want that smooth ghetto bass.
How do I get it? Do I up it to 2 12"s? 15"s? Do I get top of the line 10" subs? Is it the amp?? Do I just drop a ton of cash on equipment? Give me advice audio heads!!!
CHECK MY SYSTEM OUT! I HAVE TWO 10in RE'S IN A PORTED BOX BUT THIS IS A CUSTOM BOX....THIS CRAP IS LOUD LIKE A *****!! IT HITS VERY HARD!!! MY REAR VIEW MIRROR DOESNT EVEN STAY ON ANYMORE LOL IVE TRIED EVERYTHING TO KEEP THE SUCKER ON BUT ITS JUST THE BASS! IM RUNNING IT WITH A HI-FONICS 1605D AMP WHICH IS 1600RMS AT 1OHM. IVE TRIED AUDIOBAHNS,ALPINE TYPE X'S BUT THESE SUCKERS ARE BY FAR THE BEST SUBS IVE EVER HEARD. I DONT THINK YOU CAN FIT 12'S BUT IF YOU CAN I DONT THINK THEY WILL SOUND ANY BETTER YOU WILL JUST BE ABLE TO RUN A LIL MORE POWER, JL W7'S ARE NOT MATCH FOR THIS! ANYONE UP FOR A LIL CHALLENGE LOL HERE ARE SOME PICS
Attached Thumbnails AUDIOHEADS:What's the best sounding bass????-picture-1015.jpg   AUDIOHEADS:What's the best sounding bass????-picture-1016.jpg
Old Nov 9, 2006 | 07:20 PM
JimRHIT's Avatar
JimRHIT
Looks like a nice SPL setup.
Challenge you say .... I'll take you ... and I'm sealed
Old Nov 9, 2006 | 07:30 PM
AXIS6969's Avatar
AXIS6969
WHAT YOU GOT.....ILL TAKE YOUR CHALLENGE...
Old Nov 9, 2006 | 07:34 PM
JimRHIT's Avatar
JimRHIT
3 JBL W12Gti powered of a Crown/JBL A3000GTi
I'm messin with you .. this is in my Xterra... not really a fair comparo. I'd love to hear your setup sometime though ... maybe out as some shows/meets next spring.
Old Nov 9, 2006 | 07:37 PM
antennahead's Avatar
antennahead
A friend of mine has the LaScala's, has owned them since the '70's. I am always amazed at how they can be driven with just the minimal of power. I personally prefer Transmission line bass. My Fried's always amaze people as to how deep and accurate they are, but in an auto TL isn't practical :-)
John
Old Nov 9, 2006 | 07:39 PM
AXIS6969's Avatar
AXIS6969
AWWWW MAN! LOL! DAMN THATS SOUNDS LIKE A KICK *** SYSTEM IN YOUR XTERRA... I HAVE 4 JL8W7'S IN MY TITAN...NAH YOU'LL KICK MY *** ILL PASS CHECK IT OUT..IT HITS PRETTY GOOD
Attached Thumbnails AUDIOHEADS:What's the best sounding bass????-picture-146.jpg
Old Nov 9, 2006 | 07:41 PM
JimRHIT's Avatar
JimRHIT
NICE WORK in the Titan ... I like that a lot
Old Nov 9, 2006 | 07:43 PM
AXIS6969's Avatar
AXIS6969
THANKS! IT WAS A PAIN IN THE *** THO
Old Nov 9, 2006 | 08:19 PM
dannichols's Avatar
dannichols
My step-father owned a recording studio when I was growing up and we (he) had a set of Klipschorns in our house. He got them around 1979, I can't believe they still make these! IN the 80's we used to crank them up and cause the sliding glass doors in the den to buckle. Good stuff...
Old Nov 21, 2006 | 12:40 PM
350zspl's Avatar
350zspl
you want 150 db
Old Nov 23, 2006 | 03:48 PM
Z1truth's Avatar
Z1truth
Who makes AE Subs and where can I check them out.
Old Nov 23, 2006 | 05:15 PM
  #38
Mean Gene's Avatar
Mean Gene
Thumbs up Velos
Originally Posted by os39029
Velodyne is better than Focal for best SQ? I have Focal 165KP2 in my car fronts
The servo-feedback of the Velodyne sub makes it ( IMHO ) the best sub for SQ. I was an audio moderator on ClubLexus.com for 3+ years & my fellow mod convinced me when I heard his Velodyne/Dynaudio system for the first time. They don't make Velodyne subs anymore ( I don't think? ) & Dyns are somewhat difficult to come by ( at least in my area ). Of course, we've jumped into components now!! FWIW - I'm running Focal Utopia components but a single 12" Alumipro DVC in a 1 cubic foot sealed enclosure.
I also agree that the enclosure is a key player in a thumping system. I've heard marginal subs in a solid slot-ported box absolutely hammer while some top of the line subs in a so-so box did nothing. In my experience in the 12 volt competition area, I've found that 10's provide that "snappy" bass w/fast transients & 15's provide lots of pressure ( but not necessarily a bass note that U can "feel" ). 12's, IMHO, R the best of both worlds. Just hit them w/enough power & use a good bass CD & U should be happy.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
