what door speakers are good. (not too expensive)
Old Oct 9, 2006 | 08:47 PM
edwin350z's Avatar
edwin350z
Default what door speakers are good. (not too expensive)
i recently got a double din cd,dvd, tv. which has 60x4 watts. i had a 10 w6 with a 100 watt amp system and recently sold it. so now i am used to hearing my music real loud. so one of my door speaker blew. what speakers do you guys recommend. i dont want to spend more that 100. i already have aftermarket sony(sound alright) behind the seats. i get my stealth box w/ 2 10w3 this week so i need something that sounds good accomapanied with the bass.
Old Oct 10, 2006 | 05:41 AM
SpeedRcr's Avatar
SpeedRcr
are you needing components or coax because for a 100 bucks you might as well save or try to find a used pair. i have the boston z up front and boston pro in the rear with a jl 10w7. if you can find a used pair of focals or bostons it would be a good sound choice for your budjet
Old Oct 10, 2006 | 09:19 AM
edwin350z's Avatar
edwin350z
sorry but i really dont know much about this... i plan on just replacing the factory with something a little better. so i guess i need coax correct?
Old Oct 10, 2006 | 11:39 AM
350ZREDLINE's Avatar
350ZREDLINE
well depends, you can replace the 6.5" door speaker with a coax, or you can replace both the 6.5" and the tweeter (called components).... if you are running off HU power, most components wont sound very good.
I would probably recommend coax and call it a day
Old Oct 10, 2006 | 08:41 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Better to spend a hundred a door and get some middle price range component speakers. 90% of the quality of your music ought to come from your front speakers - unless you listen to rap/hip-hop and then that figure is just 2% from what I can tell.
Old Oct 11, 2006 | 10:01 AM
mllm's Avatar
mllm
I was just on Crutchfiled.com. The only 3 options they have for doors are
5¼'s and the lowest price was $599.00
Please give me a name and model number for 6 ½'s for under $250.
Name and number on cheap behind the seats.
I want to use the factory sub location behind the seat and need a decent sub for it as well. The sub should work ALL speakers and sub. NOTE, I am NOT into load music. I want it nice, clean and smooth. Thanks for any help you might be able to provide.
HOW DO I DELETE THIS? I posted it twice, sorry.
Old Oct 11, 2006 | 10:04 AM
mllm's Avatar
mllm
Old Oct 11, 2006 | 12:27 PM
sisco534's Avatar
sisco534
I listen to all types of music , and a good cheap speaker combo that I picked up was Polk Audio door and behind the seats with tweeters for the door , ran me about 250.00 and I installed myself. I also have a 12w7 JL audio running JL 500 watt amp just to the sub. It sounds good 'crisp and clear'.
Old Oct 11, 2006 | 01:42 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Try Woofersetc.com for some cheaper prices than Crutchfield and a wide selection of speakers. You want 6.5" speakers not 5 1/4". You'll have to do a bit of work if you get really deep speakers but nothing very difficult.
Woofersetc has about 120 pairs of different component speakers from $200 and less.
Old Oct 11, 2006 | 04:02 PM
edwin350z's Avatar
edwin350z
ok thanks...
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
