Good spot to run iPod Cable to....
Old Oct 19, 2006 | 08:10 PM
Jedi007's Avatar
Jedi007
Default Good spot to run iPod Cable to....
any suggestions/pix of good out of plain view spots to run an iPod cable from my head unit?
preferably a spot with minimal-to-no cutting up interior pieces.
Old Oct 19, 2006 | 10:35 PM
Voboy's Avatar
Voboy
Well where do you want your ipod? at the arm rest area, cup holder area, or above the headunit in the compartment? The Z is very easy to run wires around.
Old Oct 20, 2006 | 05:59 AM
deluzrider's Avatar
deluzrider
run it out the back of unit. pull out the "shifter console". cut small hole in shift boot. than rest it in ur little cup holder. i have cup holder in 06. not sure what u have there if ur not 06
Old Oct 20, 2006 | 06:23 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I put mine in the arm rest with enough cable to put it into an ash tray mounted cup holder. For the most part I use mine in random play or on a play list. I'm not willing to risk wrecking my car or killing myself too many times to pick a song off the thing - I'm funny that way.
Old Oct 20, 2006 | 08:33 AM
Lsmith9523's Avatar
Lsmith9523
I have my speed connect from my Alpine W-200,,,ran into the cubby. Its not that flashy,,,but on the 06 cubby,,,you have two notchs in the rear of the cubby, the cushon mat tabs push in there to hold it in place. I used a dremmel and made the left tab hole a little bigger,,,ran my Ipod cable through there,,,You have to run the cable through the cubby before connecting to the headunit,,for the pin plug side of cable is smaller and easy to fit. I dont have any plans for my cubby,,,so my ipod sits there just fine,,,charges,,and when I am ready to remove to bring in the house, or upload,,,I just unplug it and go....I know, this is just a base set up...but works for me.
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
