Antenna issues?
Old Jan 2, 2007 | 08:49 AM
zuk_rydr's Avatar
zuk_rydr
Default Antenna issues?
Hey I have an Eclipse head unit and my radio reception is garbage. I pulled it out and made sure the antenna was connected good and checked where the actual antenna connects and it is good. Has anyone else had this issue with aftermarket HUs? ANy way to fix it? I listen to my IPOD and CDs mostly but I would like to be able to get the news and such.
Old Jan 2, 2007 | 08:51 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Did you connect the power to the amplifier in under the antenna?
Old Jan 2, 2007 | 08:54 AM
zuk_rydr's Avatar
zuk_rydr
I didn't do the install so I will have to go check. Is it supposed to be that way or not?
Old Jan 2, 2007 | 11:50 PM
350zx6r's Avatar
350zx6r
its funny cause I got the same problem with my AVIC-Z1. I had pro-installed.
AM/FM is garbage.... I need to take it back!
Old Jan 3, 2007 | 02:45 AM
zuk_rydr's Avatar
zuk_rydr
I can't figure it out....guess I need to take it to a pro.
Old Jan 3, 2007 | 05:33 PM
Beer Goggles's Avatar
Beer Goggles
The Z has a power amplified antenna that needs to be hooked up. You need to connect the BLUE auto amp on, to the signal wire (which I think is in the diagram above)
It literally should take 5 minutes to fix.
Old Jan 3, 2007 | 06:43 PM
JokerDev's Avatar
JokerDev
Guaranteed that is the problem...
Old Jan 3, 2007 | 09:16 PM
reppintha510's Avatar
reppintha510
yea had the same problem so i tapped the blue wire to the ign on power wire for the deck and voila. clear radio stations! +1 on the wire diagram
Old Jan 4, 2007 | 10:01 AM
THE TECH's Avatar
THE TECH
If you changed out your antenna for a smaller one, that could also be the culprit.
Old Feb 22, 2007 | 12:43 AM
350zx6r's Avatar
350zx6r
The tech said that I needed to purchase some sort of amp to make it work. im taking my car back w/ the diagram now...
Old Apr 14, 2007 | 08:05 AM
TurboTrey's Avatar
TurboTrey
Connect the power antenna wire, 5 minutes ago it made my reception 100x better.
Old Apr 14, 2007 | 08:10 AM
Chako135's Avatar
Chako135
lmao just get an S2k antenna and you'll be fine
Old Apr 14, 2007 | 08:07 PM
cckleung's Avatar
cckleung
I'm confused. Why does the audio unit have 2 antenna connections (ANT SIGNAL and ANTENNA) in the diagram? What are the difference? Which one is the one that supply power to the antenna amp?
Old Apr 19, 2007 | 05:46 PM
showtypeZ's Avatar
showtypeZ
Yeah, my reception is crap too, but I didn't hook up the wire so I'm going to go do that too. Oh, and I also have an Eclipse d-din unit.
Old May 8, 2007 | 09:47 AM
zuk_rydr's Avatar
zuk_rydr
Well I haven't been able to do this yet but I am still in *** crack a stan so......hopefully it will work.
Old May 8, 2007 | 09:59 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
I got to look into this
Old Jun 6, 2007 | 10:17 AM
smallello's Avatar
smallello
Damn! I wish I would've read this before I installed my HU. I get no reception either!
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
