Any disadvantages to running sub amp at 2 ohms?
Old Jan 10, 2007 | 05:48 PM
MustGoFastR's Avatar
MustGoFastR
Default Any disadvantages to running sub amp at 2 ohms?
Hoping I don't end up regretting asking this AFTER ordering the sub... but are there any disadvantages to running an amp rated to be stable at 2 ohms AT 2 ohms to get the most output from it?
Amp is a Kicker ZX700.5 5 channel amp; the sub amp is rated at 210 watts RMS at 4 ohms and 420 watts RMS at 2 ohms. I currently have a 4 ohm JL 10W1v2 and just ordered a 2 ohm JL 10W3v3.
After the fact, I have to admit I don't know alot about amp power, impedance ratings and such, so will I be good with this setup or is there something I don't know that I should be taking into account?
Old Jan 10, 2007 | 05:53 PM
cubu's Avatar
cubu
420w>210w
Old Jan 10, 2007 | 06:02 PM
MustGoFastR
Originally Posted by cubu
420w>210w
Yeah, that's the obvious bit. Just asking if there's anything I'm overlooking. Most of what I see people run are 4 ohm subs on amps running at 4 ohms...
Old Jan 10, 2007 | 06:12 PM
Mike Wazowski's Avatar
Mike Wazowski
just more heat
Old Jan 10, 2007 | 07:03 PM
MustGoFastR
More heat, huh? Hmm, so does anyone have heat issues with their amp in the cubby behind the driver's seat? I have the stock Bose sub cover on to hopefully let some heat out... Though I do have my freaky lighted nuclear bomb-looking cap mounted right behind that grill for effect, which prob blocks off a good bit of ventilation...
Old Jan 11, 2007 | 05:02 AM
350zspl's Avatar
350zspl
the lower the ohm the more power your amp is making
it will increase temps at lower ohm
some amps get really hot some don't
i run my power RF amps at 1 ohm they don't really get hot even at 1 ohm
i am doing my rf amp now at .75 ohm it will get a bit warmer i think
but not what i consider hot
i think you made a good purchase
Old Jan 11, 2007 | 06:09 AM
MustGoFastR
Cool. Now if the damn thing would just get here already!
Old Jan 11, 2007 | 07:27 AM
SpeedRcr's Avatar
SpeedRcr
you could always hook up a cpu cooling fan on the acc switch so it runs when the amp does to get air flow...
Old Jan 11, 2007 | 09:16 AM
MustGoFastR
Yeah, that's the first thing I thought of when excess heat was brought up. My amp has overheating protection, so I'll let it be for now and consider that option if it does happen to overheat.
Old Jan 11, 2007 | 06:45 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
A higher speaker impedance is also going to give you a higher dampening factor - which is a good thing. If you're looking for more quality give up the 3 dB worth of gain created by doubling the wattage output. I can't say I can here the difference between too loud 114 dB and too louder at 117 dB ... however I can here the difference caused by the distortion of an over driven/clipped amplifier at nearly any volume.
Old Jan 11, 2007 | 07:12 PM
MustGoFastR
I'm not really looking to make it louder; I don't blast my system. I'm just looking to put in a higher quality sub that happens to have a greater need for power to run well, thus will be running the amp at 2 ohms to give it the power it needs.
Old Jan 11, 2007 | 07:18 PM
first350's Avatar
first350
I'm running my Kicker 10" L5 at 2 ohms from my Kicker 700.5 amp...no problems so far. (It's also mounted behind the driver's seat, in the OE Bose cubbby)
-Peter
Old Jan 12, 2007 | 07:14 AM
MustGoFastR
-Peter
Sweet; good to know. I should be golden as soon as the new sub arrives.
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
