New Dnx7100 Kenwood All In One Special Forum Price
Old Mar 9, 2007 | 10:24 AM
  #41
scorpio29's Avatar
scorpio29
are there any differences between the 8019 and the 7100? performance wise?
Old Mar 9, 2007 | 10:29 AM
  #42
Nazar's Avatar
Nazar
Yes,
8019 does not have nav built in.
It has 5 Volt Pre-Outs.
It has more Switched outputs.
USB input is 2 I believe.
And More selectable Backgrounds.
Old Mar 9, 2007 | 11:18 AM
  #43
THEDUKE's Avatar
THEDUKE
The DDX8019 will also do DVD-Audio, but will downmix it to two channel. Plus since it is an Excelon unit it will have 2 Year warranty if purchased thru an authorized dealer.
Old Mar 9, 2007 | 11:57 AM
  #44
THE TECH's Avatar
THE TECH
What is the capability of it for satellite radios for the 7100?
Old Mar 9, 2007 | 12:26 PM
  #45
Nazar's Avatar
Nazar
Sirius... Or XM
You can do both at the same time if you get the direct plug in from Sirius and XM Traffic/XM unit via Nav Gm-Xm30
Old Mar 9, 2007 | 12:36 PM
  #46
THEDUKE's Avatar
THEDUKE
You can actually do both units using the Direct plug in for Sirius and Direct plug in for XM. All you need to use is the KCAS-220A. This is a swiching box that gives you two changer ports form just the one the unit has.
Old Mar 9, 2007 | 12:40 PM
  #47
THE TECH's Avatar
THE TECH
Originally Posted by Nazar
Sirius... Or XM
Hmm...I just bought the XM Direct unit that Terk makes. Will this work?
Old Mar 9, 2007 | 12:55 PM
  #48
THEDUKE's Avatar
THEDUKE
It will work, but you might still need the KCAS-220A if you plugging in other external media devices into the changer port. Example would be changer, Bluetooth adaptor, HD radio, etc.
Old Mar 11, 2007 | 01:25 PM
  #49
Matt8200's Avatar
Matt8200
I haven't been able to find much information on what you can do when you add a Farenheit screen. What I want to be able to do is use the Kenwood to display the controls for a iPod video and having the Farenheit showing music videos. Does anyone know if you can this?
Old Mar 11, 2007 | 02:12 PM
  #50
Nazar's Avatar
Nazar
YES and NO.
7100 will give you Video output for i-Pod / DVD / or Line Input..
So you can send the DVD Player video to Second screen... And Play I-Pod through the 7100...
Once in I-Pod viedo mode screen displays the Video automaticaly and you can Fas forward and rewind just by pressing the right side or left side of the screen.
Old Mar 11, 2007 | 05:59 PM
  #51
Matt8200's Avatar
Matt8200
Ok, I want to send the I-Pod video to second screen, mostly because it would be in a more visible location. If you send the I-Pod to the second screen can you have the 7100 displaying its GUI?
Old Mar 11, 2007 | 06:45 PM
  #52
THEDUKE's Avatar
THEDUKE
Yes you can.
Old Mar 12, 2007 | 10:17 AM
  #53
skbest11's Avatar
skbest11
Nazar, pm sent
Thanx
Old Mar 12, 2007 | 12:36 PM
  #54
evolved326's Avatar
evolved326
OMG this is HOT! Ive been waiting for somethign to come that is all in one and has NAVTEQ and its here! It has Garmin interface to boot.
Great deal! Can you please send pics of it with the nav in action. Cant seem to find it online. Thanks!
Old Mar 12, 2007 | 02:36 PM
  #55
THE TECH's Avatar
THE TECH
Is there any way to connect the rear view camera and switch to it whenever you want to versus it coming on when you go into reverse?
Old Mar 12, 2007 | 03:10 PM
  #56
Lancaster's Avatar
Lancaster
I've been browsing through the pdf manual~ But to get the bottom line, is there anything the new D3 does that this wont? Besides multi color backlighting
I was about to order a D3, might rethink if the 7100 is more attractive in all ways except cost.
did I read correctly? it uses 2v preouts
Old Mar 12, 2007 | 03:28 PM
  #57
THEDUKE's Avatar
THEDUKE
You can add a toggle switch and activate it that way. When you flip the switch it thinks you are puting the car in reverse and activates the camera.
Old Mar 12, 2007 | 06:05 PM
  #58
azula's Avatar
azula
the 7100 is definitely hot, i just need to sell my kenwood ddx 8017
Old Mar 12, 2007 | 08:18 PM
  #59
THE TECH's Avatar
THE TECH
+1. I'm still trying to sell mine.
Old Mar 13, 2007 | 05:19 AM
  #60
Nazar's Avatar
Nazar
Or you can use a Y-Adapter where the video signal comes in from the Camera and plug it in the Line-In for video. This way you can select ot with the V-Select button on the deck.
