Cheapest way to get just a lil' more bass?
Old Apr 8, 2003 | 08:49 PM
afr0puff's Avatar
afr0puff
Default Cheapest way to get just a lil' more bass?
I'm not looking for a heart rattling boom. I'm just looking for a little more bass. My damn speakers rattle way too easily or the audio becomes overmodulated. Just getting better rear speakers? Or do I need to get an amp and a sub?
Old Apr 8, 2003 | 10:59 PM
bastard's Avatar
bastard
Default Re: Cheapest way to get just a lil' more bass?
You could maybe get some line level converters and patch in an infinity basslink.
Old Apr 9, 2003 | 07:42 PM
Encore's Avatar
Encore
Amplified bazooka tube. You could stick it in the compartment behind the driver, and loose no room. Not the most thunderous bass, but will give you some bottom end.
Old Apr 9, 2003 | 08:15 PM
spiroh's Avatar
spiroh
install an 8 or a 10 in the back.
Old May 10, 2003 | 05:33 PM
ICYBLUE1203's Avatar
ICYBLUE1203
I am in the same exact situation. I just replaced the 4 speakers, but a sub is needed because it does not sound right. I was thinking of a Basslink sub/amp since I most likely could install it myself, but would a regualr sub + amp end up being cheaper, including installation?
Old May 11, 2003 | 10:35 AM
damen's Avatar
damen
i was looking at getting the 10" basslink to put into my G35 coupe. does anyone know if it is a nice speaker and amp?
Old May 11, 2003 | 10:49 AM
Stone Z's Avatar
Stone Z
raceboy has one....you should ask him how he likes it.
Old May 11, 2003 | 11:22 AM
damen's Avatar
damen
thanks i'll look for him
Old May 12, 2003 | 11:35 AM
zdriver1's Avatar
zdriver1
Just got an 8" powered Bazooka. Not the coolest set-up, but it's clean, affordable and doesn't take up a lot of space. Mounted it in the passenger side, rear corner and it sounds better than I thought it would. If you just want a little more low end, you should consider it. It's got decent response (the small size of the Z's interior helps) and it doesn't overpower the stock stereo. It will also lessen some of the stress from the front speakers, so in return you'll get cleaner sound at higher volumes. I have my bass setting at +2 now instead of +5, where it was before I got the sub.
Old May 19, 2003 | 10:52 AM
jhagan's Avatar
jhagan
just went through this a few weeks ago.. build a box. bya 10" sub and stick it behind the drivers seat.. Good tight bass. search the forum for measurements.. If you search for sub.. there shold be a post asking about the size of the stock sub location.. read that thread.. if not PM me.
CrowzRSA
Sep 21, 2015 04:00 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
MustGoFastR
Jan 11, 2005 11:56 AM
jelledge
Jun 4, 2004 10:17 AM
Brad4rdHay
Sep 29, 2002 04:36 PM
